Houdini
Titanium
- Nov 28, 2017
hello all, I need a recommendation for a Aluminum bar stock saw for CNC machine shop.
I have used in the past machine shop automatic band saw's, but the blade speeds are always limited so it is a slow process.
I currently use a 12" wood cutting miter saw, I was using one of the 14" dry cutting metal saws, but once again the rpm's are for steel, cut too slow.
I would like to currently while the shop is small just buy a manual aluminum saw with carbide tipped blades high rpms, and coolant system.
but in about a year i want something fully automatic.
these are for aluminum only
i will buy a automatic band saw for steel later, i dont do any steel currently, so the manual dry saw is usable.
I dont want to buy any chinese import junk, something I buy once.
Thanks for your help.
