Recommendation needed for milling machine gearbox viscosity
Results 1 to 10 of 10
    Oct 2017
    BELGIUM
    7
    7
    Question Recommendation needed for milling machine gearbox viscosity
    Hello,
    I have a MAS FU 2A milling machine that I am cleaning up and servicing. One of the next jobs on the To-Do list is to flush the gearboxes and put new oil in.
    Was not able to find out wich oil is recommended by manufacturer. What came out I can only describe as Mystery Oil. Got a fair suspicion that it was topped up with whatever was on hand.
    I'll probably go for MOBIl DTE or Shell Omala S2. These are without a doubt better than anything that was available when the machine was new.
    But here is the thing I have no clue to wich viscosity grade should go in. My best guess It's probably within a 68 - 100 - 150 range.
    That's why I would like to know what others use in their milling machine Spindle speed Gearbox and power feed gearbox
    Thank you in advance, any help or advice is appreciated.
    Jul 2007
    Missoula Mt
    423
    15
    165
    Dont use Mystery Oil, mostly acetone ....Phil
    Jun 2013
    Buffalo NY USA
    533
    349
    285
    Quote Originally Posted by Phil in Montana View Post
    I am pretty sure he did not mean the brand, marvel mystery oil. Rather, he meant that the oil which came out is a mystery.
  4. Likes Elky liked this post
    Apr 2015
    Ohio
    153
    54
    I would start out with ISO68 if it leaks put a thicker oil in.
  6. Likes Elky liked this post
  7. #5
    Aug 2006
    New Zealand
    1,306
    78
    279
    Hi
    I went through this saga with my own machines. I went as far as consulting with a tribologist at a major oil company.
    You have already said that modern oils are better than anything available when the machine left the factory.
    I use either ISO68 or 90 grade non-EP gearbox oil. EP oil contains sulpur and other products that erode brass/bronze type materials.
    Dazz
  8. Likes Elky liked this post
  9. #6
    May 2005
    Republic of Arizonia
    1,662
    499
    My suggestion is ConocoPhillips Syncon R&O 46 or 68.......Running 150 in a HBM
  10. Likes Elky liked this post
  11. #7
    Dec 2002
    Benicia California USA
    8,399
    1969
    2737
    Oil type and viscosity are dependent on what it lubricates. If your gear box also lubes the spindle bearings , then IMO you need something lighter and not a gear oil.
    Suggest AW 46 (anti wear hydraulic oil) Has additives to prevent wear on gears, and its light enough to be a good lube for close running spindle bearings....won't affect bronze bushings.
    Cheers Ross
  12. Likes Elky liked this post
  13. #8
    Oct 2017
    BELGIUM
    7
    7
    Thank you, for the suggestions.
    Yep about the mystery oil, I meant it is a mystery what sort of oil it exactly is. It's fairly thick oil that came out.
    But the machine also weeps a bit on some covers and shafts. Nothing I can't fix. They probably topped it up with numerous kinds of different oils.
    Hey at least it had oil in it and wasn't run dry as far as I know. When I flush it with kerosene I expect to find numerous leaks I intend to fix.
    I most likely will go with the MOBIL DTE Heavy Medium or DTE Heavy also got a local supplier near me. That's always handy.
    The DTE Heavy Medium is 68 and the DTE Heavy is 100. Can't find any information if the DTE Heavy medium is a non-EP oil or not. The DTE Heavy is advertised as a non-EP oil. Could assume it is the same for it's sibling? Because I think the 68 would be a better fit after seeing the types of oils recommended in above posts
  14. #9
    Oct 2017
    BELGIUM
    7
    7
    My Google searches did result in suggesting Shell Tellus S2 46 hydraulic oil for some machine gearboxes.
    Sadly I haven't found any information from the manufacturer on this machine. My best guess would be to rely on what came out of it which is also unreliable.
    The oil that came out was fairly thick, I presume they added thicker oil because of the weeping.
    Hmmm, Yeah
  15. #10
    Aug 2014
    Wisconsin Rapids WI
    239
    35
    My Rambaudi uses DTE Heavy. the motor is 5 hp and the top rpm is 1500. Dave
