NickC62
- Nov 4, 2021
Looking to get some mild steel, thin walled (1-1.5mm)tube drilled with diamond pattern close drilled holes. Seamless tube with an OD of 20-22mm
Must be drilled as opposed to laser cut as i'm thinking too much debris will be left on the inside of the tube for my application.
If you know of, or can suggest anyone who could do this in the UK please message me.
Regards
Regards
