IMHO, the only countersink to buy and use anywhere is the O flute countersink. The biggest advantage of this style is that chatter is almost impossible.
And YES, some brands are pure garbage. It is hard to get the necessary clearance right. Half of the hole needs to be high to form the cutting edge and the other half of the hole needs to be at the low end of the helix that forms the clearance behind the edge. The cheap ones do not get sharpened correctly and do not work right. Get a name brand. I started with a name brand set of five sizes and then purchased replacements that are also name brand.
A properly sharpened O flute countersink will easily cut a proper, smooth countersink in almost any material. At least any material that I have ever tried. And they work in a rigid mill/drill, in a drill press, in a hand held power drill, and even in a hand held hand powered drill. They just plain work.
Some feel that they are hard to sharpen. I have sharpened them with repeatable success. There are two methods: the easy one is to use a round stone (cylindrical) in a Dremel type tool. Run the Dremel on a somewhat slow speed and insert the stone in the hole in the countersink. Keep it parallel to the hole's axis and work on the cutting edge. This method only allows you to resharpen it a few times before the geometry is distorted: the cutting edge becomes too weak to hold up.
A better, but more difficult method is to take down the entire "cone" by a roughly equal amount. I like to use a slow wheel for this instead of the typical, high speed bench grinder. I have a Craftsman unit that has a built in water bath to keep the wheel wet. I start on the low end of the cone's helix with the tangential point on the stone about half way across the hole in the countersink. Then I rotate the CS backwards until the stone contacts the CS at the high end of the cone's helix. I try to keep the rotational speed of the CS and the pressure constant throughout this motion in order to keep the amount removed constant across the entire cone. This is repeated as needed. This can be done on either the round edge or the flat face of the abrasive wheel: I usually do it on the edge. The edge would be dressed flat/straight for this. If this is done hand held, mounting the CS in a loose drill chuck is a good idea.
With care, a bad O flute countersink could be improved by this second sharpening procedure, but many of them are not properly hardened so the effort is not necessarily rewarded.
