I had a USA 18N chuck that was difficult to open, so I pressed in a part, degreased everything and used Super Lube as the grease on the innards. It is very smooth now but it seems like maybe the Super Lube was too thick. I bought a unused NOS USA 18N, and that chuck just spins open really easily. I don’t think it was messed with. It must have a heavy oil or thin grease inside. The Jacobs chuck rebuild info says to use a “good grade of grease.” Kind of vague. Super Lube is NLGI 2. I have a bunch of options in my shop. I have Mobil synthetic NLGI 1 and 2 grease, Mobil Vactra 2 way oil ISO VG 68, Mobil DTE 24 hydraulic oil light, hydraulic oil AW ISO 32, white lithium grease, 50 wt oil, 10 wt oil, 5w30 and 10w30 motor oil.
I just got a USA NOS Jacobs 11N that is really sticky. I want to get this little guy running nice and smooth. What lube would you recommend that will allow the collar to spin easily but be effective on keeping the bits inside well lubed? Thanks in advance.
