adammil1
Titanium
- Mar 12, 2001
- New Haven, CT
I just picked up the following steam whistle the problem is it is missing the valve which is essentially a poppet that sits at the bottom of it and seats on the angled surface shown below. The seats didn't look to be in the best condition and they seem to have somewhat of a radius on them. Rather than try to reverse what's there and try to machine it into the new poppet I am wondering if now may be a good time to recut the seat and start with something known so that I can cut a new valve with seat to fit it. I am thinking ideally just go with 45 deg then finish lap in place the new valve? Or is this nor a good idea for a steam valve?
I am not in the shop right now but the OD I believe is 2"pipe thread for an idea of size.
What's the best way of doing this? Ebay is loaded with valve cutter kits but I only need one size and to use it once on cast bronze. HSS should work fine here. Where's the best place to buy them? I did a quick search of Mcmaster and MSC but didn't see them but perhaps I am searching wrong?
Then next thing do you just machine up a bushing to fit the ID and turn it by hand or how are valve seat cutters typically used? Fixturing this thing in on the mill or lathe seems out of the question so I am thinking I need something to hold onto the ID. How tight should the clearances be on such a bushing set to avoid chatter? Anyone have any advice for someone whose never done this before?
Adam
Sent from my SM-J737V using Tapatalk
View attachment 322472View attachment 322473
Adam
