Recreating odd shaped objects in CAD
Results 1 to 10 of 10
    Dec 2018
    CANADA
    Ontario
    Default Recreating odd shaped objects in CAD
    I was wondering how to recreate an odd shape in to a CAD file accurately. Are there any proper ways to do so? Here's an example img-3964.jpgimg-3962.jpg
    Apr 2018
    ALAND ISLANDS
    I would start with a more regular shape and then cut away or use a revolve.
    Hard to get more detailed without the computer right in front of me.
    Sent from my SM-N950U using Tapatalk
  3. Likes food. liked this post
    Apr 2016
    Arizona
    207
    166
    78
    How accurate do you need to be? ±0.001"? ±0.1"?
    The most you can generalize about is the problem of measuring to a certain tolerance, the actual how of making geometry in CAD is extremely object, CAD program and workflow-specific.
    For small-ish stuff (like under 1' in every dimension) that just needs to be "visually right", I'll often figure out a way to section (not literally cut, just measure/mark out) the object into multiple "slices" measurable with a caliper or other hand tool, then draw the measured sections and link those together with whatever geometry makes sense to use in Solidworks. The exact method depends on the size, shape and symmetry of the object. I do a lot of automotive trim type pieces this way. Someone who needs to hold tighter tolerances likely has a different method. Having a good rapid prototyping method helps a lot here, at least until you get really good (which I'm not).
    I've also used a Leica Disto to make point clouds of things that can then be used as references to drive models. Usually copious photographs and note-taking is required to make sure the point cloud data is properly interpreted. This is for furniture/architectural scaled stuff.
    I often have non-manufacturing people bring me a part to be reproduced and ask about "3D scanning" it. From my limited experience, unless you have really good scanning equipment and a super complex, detailed object (like a hand carved intricate scupltural surface), it is better and faster to just model it from scratch. A scan will need to be cleaned up and will not produce true straight lines/prismatic surfaces (most efficient for CNC programming) automatically. Take this with a grain of salt as I'm not up to date on the latest/best scanning tech, which I'm sure some others on here know better.
    Also, there is a CAD forum here, looking through some old discussions here might be helpful. https://www.practicalmachinist.com/vb/cad-cam/
  5. Likes Bobw, food., Pattnmaker liked this post
  6. #4
    Dec 2018
    CANADA
    Ontario
    For my task it only has to be around .1"+- so I think I'll try doing the multiple slices method that you've mentioned, thanks a lot for the input.
  7. #5
    Jun 2001
    St Louis
    17,373
    1585
    2759
    Most CAD packages have a couple handy features.
    One is the ability to "push" or "pull" surfaces. That can let you eyeball the thing into a good reproduction of a shape by "pounding the surfaces" into proper shape..
    The other, and more useful one is a variation of the slices, where you use guide curves to make an extrusion conform to a set of lines through the sections. Or, you may let the software create a shape with a surface that goes through each of the sections,
  8. Likes carbonbl liked this post
  9. #6
    Jan 2006
    Angier, North Carolina
    2,327
    774
    748
    Quote Originally Posted by carbonbl View Post
    Photogrammetry (sp?) is a generic term for generating a model from a series of pictures - which is basically what some 3d scanning consists of, as best I understand it. I keep meaning to check it out - supposed to be FOSS programs to do this ... but whether the results are even vaguely usable is, as carbonbl points out, is another question.
  10. Likes food. liked this post
  11. #7
    Feb 2009
    Wisconsin (from May to November); Florida (from November to May)
    1,618
    43
    389
    I have been doing this for years. The cheapest way is to get yourself a Microscribe digitizing arm and a copy of Rhinoceros software. The software costs about $1,000, and allows you input points and splines with the Microscribe digitizing arm. The points are used to align your workpiece with the Microscribe arm. The splines are used to create the 3-d object, so that be used in a 3-d cad cam system like Mastercam. The accuracy of this drawing is within .009 of the actual part that you are trying to draw. You could also buy a Faro arm that would have a closer resolution compared to the Microscibe. My Microscribe arm cost me about $5,000, the Faro arm is about $12,000.
    Be aware that learning 3-d geometry will not be a simple process which you may or may not have the inclination or patience to master.
  12. Likes food. liked this post
  13. #8
    Dec 2018
    CANADA
    Ontario
    I didn't know about the push and pull abilities thanks.
  14. #9
    Jun 2001
    St Louis
    17,373
    1585
    2759
    Quote Originally Posted by food. View Post
    Not all CAD has that, and it does not work on all surfaces.... You will have to look and see if it is a feature for yours, and what it works on. I use Alibre, which has that.
  15. #10
    Sep 2005
    Oakland, CA
    2,183
    136
    529
    You don't mention what CAD platform you have access to, but if you have Solidworks, the following works quite well. Lay the part on a copier or scanner that can output a jpeg file and take at least two scans with the part positioned 90 degrees from the 1st scan for the 2nd "picture". In SW, import the two scans into separate sketch pictures. Now you can sketch around the outline of the sketch picture to develop the shape in two perpendicular planes. If you go into Tools/Options and turn on Autotrace, this can make creating your sketch much easier- (there are multiple YouTube videos on this). Once you have your sketches made you can develop a lofted surface between the sketches. If you need better precision take some measurements of the part at different locations and tweak your sketch shapes to those control points. Have fun too!!
