Hi
As I told a couple times before I'm fairly new to cnc machining. And still learning each day.
We machine 99% of the time aluminium.
Most of the parts got some inner pockets. At the moment we use a endmill to helix into the material and rough it out. Not the fastest way and we're searching for something faster.
The options we got is a indexable drill, to drill the hole which the endmill can enter.
Or getting a ripper (pro-x) mill to rough out the pockets. Which is a bit faster and will save on 2 tools in the toolchanger.
"problem" is that the 25mm pro-x mill wants around 12.000RPM. But we only have 6000RPM. would this work? And how should I adjust the feed/chipload because of the lower RPM?
Trying to search for a way to reduce cycle times
