Reed Prentice gear head lathe ?
Likes Likes:  0
Results 1 to 15 of 15
    Jan 2008
    Valdez, Alaska
    204
    50
    92
    Default Reed Prentice gear head lathe ?
    I've just aquired a Reed Prentice lathe. the lathe is biggish, 96" between centers, about 22" swing over the bed. 7.5hp General Electric motor. I've gotten it 80% cleaned up, leveled and wired and now I need to bolt it down and do the final adjustments.
    I don't have any documentation for this lathe so I'm a little reluctant to start making adjustments to things.
    The only numbers I can find are on the cross slide and on the bed at the very end next to the tail stock. There is also a stamp "US" with an anchor in the middle, possibly a navy stamp.
    Are there any other places to look?
    Where should I start looking for a manual?
    how old is this thing?(I know that I'll have to post a serial number for that)
    will I go to h#ll if I don't repaint the dark green a proper gray?
    where can I get a spanner to change chucks?
    how do I change chucks?
    It really is in very nice condition, just a little loose on the cross slide. The marks(little "V" shapes) from scraping are still visable on the whole bed but worn next to the chuck, nothing broken. I do need to replace three site glasses, one of which does have a hole at the top and replace a couple of the little ball oilers.
    Inside the gear head there is no rust, the oil is clean, good oil in the cross slide and feed case?. It just shines except the bugly green paint.
    It has a #5 mt tailstock, taper attatchment, four and three jaw chucks, I don't know the name of this, a large round plate with slots for mounting odd shapes, two steady rests and a boreing bar holder with .75", 1" and 1.25" holes.
    thane
    PS if you think the west coast is a tool desert, come to Alaska. even if you find a tool it is probably a three day boat ride to get to it.
    Jul 2004
    Houston, TX USA
    30,752
    Since you need a "spanner" to get chuck off, it is post mid thirties, when the three types of standardized spindle noses came out. You have the "L" type, very possibly in the L1 size.
    You get the chuck off by unscrewing the draw back nut after you get or make a hook spanner. By unscrewing, I mean top of nut goes to rear.
    Some are built so when you unscrew it far enough it will shove the chuck off the tapered and keyed spindle nose. Do what ever is needed to not let the chuck fall on you or the machine.
    Serial may be stamped on bed near right end.
    Jan 2008
    Valdez, Alaska
    204
    50
    92
    Thanks Johnoder, then I've the correct number, I thought that I could get the correct rotation off of the the other chuck, hints on a manual?
    This lathe was first posted by PWSF before I got it. He and I go way back and have similar weaknesses.
    Jul 2004
    Houston, TX USA
    30,752
    As with a great deal of this old stuff, there is apt to be more sales info than actual manuals. Forum member Widlin scanned some of my old (older than your lathe) RP sales info, and may have more in the way of manuals.
    Here is a scan showing some of the stuff the threaded spindle nose RP could do.
    http://img.photobucket.com/albums/v3...er/RPChips.jpg
    Sep 2003
    Bel Air, MD
    229
    6
    Congratulations on the lathe. As John said I do have a scanned copy of his sales brochures that I could send to you on a CD. I also have an original manual (and a few photo copies of it) from the early 50s that I used to help put my 1941 Reed Prentice back together. I have been meaning to scan that manual for quite some time, as the members of the Yahoo Reed Prentice group that I try to moderate have heard me say many times before. At work we now have photo copier that will scan the 11x17 drawings and e-mail me a PDF, so maybe I can do that over the weekend or a little each morning. Also as John said you need a spanner ranch and probably a dead blow hammer to get the chuck off by turning the collar clockwise when facing the chuck. The collar is threaded onto the chuck so this will unscrew the two. If you are interested I could also send you a copy of the manual, it won’t be as good as a PDF that you can enlarge though.
    Jeff
    Dec 2005
    Southern Ohio
    1,022
    7
    Congrats on the R-P. My 14 x 30 is about 3 years old (to me). Mine required a lot of disassembly just to clean it up and make sure all the pumps and filters were OK. Hopefully your machine has the pump in the apron that keeps the ways oiled. It virtually eliminates wear on the ways. Great machines.
    You may want to search for an old thread about the sight glasses. I couldn't find replacements in glass and I wasn't happy with any of the available plastics. Here is a photo of my solution. I machined a pocket into the cover and glued a glass circle into it with clear silicon. A local window shop cut the glass discs. The shoulder is the same depth as the glass thickness. The shoulder side goes toward the machine and a gasket laps out onto the glass a little. Three years and no discoloration or leaks.
    I am happy with my 14 x 30 but I wish it was as big as yours. (size envy?) :-)
    SCOTT (fabricator - wanabee machinist)
    Jan 2005
    Ohio
    298
    14
    30
    Hi seiner,
    Sent you a pm regarding your machine.
    Johnny V
    Jan 2008
    Valdez, Alaska
    204
    50
    92
    smootz,
    I like your fix, the plastic lenses in mine are domed and badly yellowed, yours look much better.
    Jan 2008
    Valdez, Alaska
    204
    50
    92
    serial number is 29944 on lathe bed, 23238 on cross slide
    Jul 2004
    Houston, TX USA
    30,752
    Was made in 1944
  11. #11
    Jan 2005
    Ohio
    298
    14
    30
    Hi Seiner,
    I sent you a Private Message regarding your machine.
    Later
    Johnny V
  12. #12
    Nov 2019
    Colorado
    Morning , I see that this is an older thread but thought I would give It a try anyway , I have a reed prentice lathe with no tags or name plates on it ? The numbers on the bed are 32621 it’s a 16 x 60 I would greatly appreciate any information anyone could provide , thanks
  13. #13
    Aug 2012
    California, Central Coast
    4,262
    2256
    1686
    Quote Originally Posted by W900 View Post
    Your question is like asking "I have an old car, it has 4 doors made is 1972, tell me about it."
    Dude, quit digging up ancient threads and asking the same question.
    Start a NEW thread about you lathe and dont start it until you learn how to post PICTURES of the lathe.
  14. #14
    Feb 2020
    Kentucky
    6
    Sir how wpuld i go about trying to get a cope of that ?
  15. #15
    Jul 2004
    Houston, TX USA
    30,752
    Quote Originally Posted by Bobbyrhamby View Post
    Bobby - if you are referring to user name widlin1, he was last on the forum a year ago, but you could click on that name and send him an email and see if he responds to same. Maybe he has a link to his manual by now - but maybe not
