MAFrecycling
- May 28, 2020
Hey everyone, new to the forum here. Just a quick introduction of myself...I’ve worked in the drilling and blasting industry for the last 8-9 years now and have actually started my own business recycling scrap mining drill bits. As of late I have been toying with the idea of attempting a process that can refurbish DTH hammer bits. I have already figured out how to remove the carbide buttons that aren’t broken efficiently, but I can’t for the life of me figure out how to remove the broken buttons that are recessed in to the steel. This would essentially be like a tap that broke off a half inch or so inside a hole that you needed to get out, but instead of HSS it’s tungsten carbide.
My best thought is perhaps a PDC Air chisel? The carbide is extremely brittle and breaks apart quite easily when hit against more carbide, so I’m hopeful that a PDC air chisel being harder than the tungsten carbide would hold up and I would be able to chip away the broken pieces until I can clear the hole for a new insert (the holes are 19mm in diameter, so I’ve got some room to play with)
Just wondering if anyone Has any suggestions is all, finding any kind of information on how to work with tungsten carbide is quite scarce so it seems...thanks for any help!
