Refurbishing an Index Rotary Table
Likes Likes:  0
Results 1 to 4 of 4
    Mar 2006
    Wisconsin
    1,051
    14
    354
    Default Refurbishing an Index Rotary Table
    I recently acquired a 12" Index brand rotary table. This table is pre Wells index in that it is labeled "Index Machine & Tool Works" with the Jackson Michigan address. It's in useable condition, but before putting it to work I was going to at least clean off the years of dirt and gunk and lube it. I was also thinking while it was apart it might be appropriate to surface grind .010" to .020" off the top to eliminate some of the past indiscretions. Fortunately I've never had to attempt to grind the top of my other rotary tables so I'm not sure if it's something that can or should be done. Any advice on the subject would be appreciated.
    I would also like to know if anyone could lead me in the direction of any publications like parts list or owners manuals concerning this unit.
    Nov 2003
    Beaumont, TX, USA
    4,895
    171
    1483
    That's a nice old RT.
    Before doing any milling or grinding on the top I would make an attempt to see just how square it is to the vertical axis. Make the table top square to that axis and then check that the bottom of the base is parallel to the table top.
    Sep 2008
    Canada
    910
    359
    328
    Nice RT. Were it me, I'd strip, clean it, and measure wear. I'd scrape the bearing surface back to parallel with base on both base casting and the table with a reasonable bearing ppi. I'd want the center hole truely vertical. Only after that's done would I look at the top, and unless it's more than a few thou out from the parralel and flat would I grind (or preferably mill) it flat first and then scrape the top into whatever tolerance and ppi you need/ like.
    Or just use it and live with it.
    L7
    May 2003
    4,493
    252
    I picked up a similar table made by Gorton, it had been knocked around quite abit, but all I needed to do was knock down the burrs with a scraper, and lightly stoning, the old table still had great accuracy.
