That's all we've ever used....don't need anything more...
For what it is worth - One of the first things I tried was Acetone and it did not work at all.
Perhaps the "ink" used at various manufacturing sites is not always the same.
The Aluminum Hex Rod I bought here in Spokane, WA said Kaiser Aluminum in
that Black "Ink" and would not respond to Mineral Spirits, Acetone, MEK, Methylene Chloride, Xylol, Isopropyl Alcohol, Terpentine, WD-40, Hoppe's #9, Wipe-Out Patch-Out, Sweets 7.62 Solvent, 409 Cleaner, Rust Out Cleaner, Tap Free Cutting Fluid, ATF, Kroil, Gummout Carb Cleaner, and "spit".
All I can say is - if you can't dissolve the ink you have in front of you, try the
Klean-Strip Premium Cleaner. It worked
instantly. Just nasty stuff to use inside and you'll need gloves to keep it off your skin.
I know others claim various things work, but I tried them and nothing worked but
the stripper I mentioned. That is what makes me think the ink varies from place to
place and maybe time to time.
I thought that maybe the ink contained Selenous Acid which is in Birchwood
Casey's "Aluminum Black" Metal Finish for Firearms.....but - looks like not.
Have a nice day.
DoctorBill
From Post #24 (From the future !):
"Maybe after that aluminum was extruded, it was still too hot when they coded it. If that was the case it would be very difficult to remove."
Michael Edwards
I posted this forward explanation to forestall some of the Bizzarre replies you will see.
I am sure I WILL offend someone !
