tay2daizzo8
Hot Rolled
- Nov 8, 2013
- north of Bean town
Removing motor from Kondia Varispeed mill
Hi Everyone,
I have a Kondia Mill im trying to remove the motor from. Im stuck trying to get the pully off the shaft so i can pull the motor.
One place i saw referenced two tapped holes in the spring loaded plate on the bottom of the motor to release the tension? but i have not 2 screw holes but one hex bolt . Im afraid if i start cranking on this bolt the spring will come flying out and ill be SOL. or maybe i just need to remove the belt but it doesnt seem possible without taking off the motor.
Im taking it apart because there is an issue with the motor itself, my repair guy said it want receiving full voltage to the motor but was getting full voltage at the connections to the motor.
Any help greatly appreciated
Hi Everyone,
