removing rust with citric acid
Page 1 of 2 12 LastLast
Results 1 to 20 of 39
    Feb 2010
    ch
    3,302
    275
    458
    Default removing rust with citric acid
    i thought i would share my latest findings.
    if you have light (surface) rust, a saturated citric acid solution will work well and not discolor steel like other methods. let it soak overnight, rust will be gone and a polished surface still shiny. its especially interesting if the part is large, because citric acid costs nearly nothing. i got 11 lbs for $15 and that is food grade. this gives you 10 gallons of solution for around $2.
    i left a polished piece of mild steel in there for 3 days and it got a very light coating (i wonder what it is) that was removed with a kitchen sponge quickly. nothing like the black phosphate you get with phosphoric acid. unlike vinegar (the other inexpensive rust remover) citric is odorless.
    Oct 2018
    UNITED KINGDOM
    26
    8
    Good afternoon.
    That's interesting. I work on motorcycles, & often find rust in the petrol tank, especially on bikes that have been standing.
    I use a product called Bilt Hamber Deox-c which is available here in the UK. It leaves the steel bright & shiny with no residue whatsoever. As it's considerably more expensive that Citric acid I'm going to give Citric acid a bash & see how it performs.
    Cheers.
    Stew.
    Oct 2013
    NETHERLANDS
    2,020
    949
    853
    beware of hydrogen embrittlement
    Jul 2007
    Missoula Mt
    1,389
    61
    667
    hydrogen embrittlement would not a problem, citric acid works so slow it would take years, the water would rerust the part before that would happen. I use citric acid to clean water passages in old engines...Phil
    Nov 2006
    Southern California
    1,140
    11
    146
    Interesting. What dilution ratio are you using? Have you tried it with heavily rusted steel?
    I currently have been using animal grade molasses diluted 10:1 with water for rust removal. In the attached photo, I have two fairly rusted 1/2" nuts from the same project where one was soaked in molasses for 6 days and the other one is in the as-found rusted state. Post molasses bath, I wash with water and air dry. The I use red scotch bright and solvent to polish off any left over film from the molasses or sometimes a thin layer of black oxide? It took about 30 seconds to clean 8 surfaces on the nut as shown.
    I'll have to try citric acid and see how that compares to molasses.
    Feb 2010
    ch
    3,302
    275
    458
    actually i have a number of pipes outside sitting in 15% molasses. it works and is also inexpensive, but it usually takes a week or more as you say. insects get attracted and in winter it takes even longer indoors. it was not easy to get molasses, btw.
    the citric acid is saturated and and only for light rust, because its slow. i find its less of a mess than molasses, would be interesting to see which is faster.
    for heavy rust i use phosphoric but its expensive. i think for big, really rusted parts electrolysis would be the way to go.
    Aug 2005
    South Australia
    237
    27
    47
    I use molasses 1:9 of water to de-rust but also to descale hot-rolled steel prior to machining. In summer it takes 2 days to perform the latter function. It CAN look like not much has happened but when hit with a jet of water from the garden hose the surface is left clean light grey almost like cold-rolled. My 'vat' is a 200litre black, poly pickle barrel with screw-on lid. Outside, it only gets the sun from noon on but the heat helps. Must try citric acid for small items.
    Feb 2010
    ch
    3,302
    275
    458
    i have noticed molasses are more popular down under than elsewhere. probably due to temperature.
    Sep 2006
    Sacramento County, California
    4,359
    2793
    1694
    Quote Originally Posted by dian View Post
    Locally near me at a chemical outlet, phosphoric is sole in 70% solution for $20-25 a gallon. It can be cut with water to make up to five gallons. It works well when diluted only takes longer to remove rust. It does darken metal, however but that's a good thing for me, since it won't rust again very soon.
    Heated phosphoric acid is the basis for the Parkerizing process that is sometimes used on gun and automotive parts.
    Parkerizing - Wikipedia
    Jul 2006
    rochester, ny
    2,348
    581
    754
    I've citric acid to derust parts. It worked fine, but I forgot about a batch for and it ate into the steel. Don't remember how long they were in the bath, sorry. Now I prefer Evaporust, safer if stuff is in too long.
  11. #11
    Apr 2018
    8,084
    3970
    Consider yoruself lucky, used to get it on my pancakes. Reminds me of ...
    I hate Bosco !
    It tastes like chocolate pee.
    Mommy puts it in my milk to try to poison me !
    I fooled mommy
    I put it in her tea
    Now there is no mommy, to try to poison me !
    Used to be common at Safeway but I haven't seen it there in years. Now they just have that phony Aunt Jemima crap that isn't maple syrup and isn't molasses. Bain Capital musta bought them.
  12. #12
    Nov 2006
    Southern California
    1,140
    11
    146
    You can buy 5 Gallon buckets of molasses pretty cheap at the animal feed store.
  13. #13
    Apr 2020
    Ohio
    1,340
    1152
    491
    I second the Phosphoric acid, I get it at autozone but I’m sure it’s pricy compared to other stuff in my situation. I REALLY suggest and prefer over anything the loctite naval jelly rust dissolver, I didn’t notice any darkening of my mill when using it on the ways (index 55 rusted to hell) and I left it on a few times way too long and it hardened and turned white, I then put a new layer on it and that took all the white stuff off and worked great, after cleaning the jelly off you must oil the parts or they’ll rust almost immediately. I also used the rustoleum rust dissolver and it lists phosphoric acid but it leaves a film of something behind to protect the metal and I dislike that.
    Edit: this is for “small” parts in my situation At or smaller then a bp guideway
  14. #14
    Feb 2010
    ch
    3,302
    275
    458
    Quote Originally Posted by crrmeyer View Post
    they didnt even know what it was. doesnt get used anymore. had to special order it. i live in a "high tech" country, unfortunately.
  15. Likes Homebrewblob liked this post
  16. #15
    Apr 2004
    Modesto, CA USA
    8,626
    1649
    I use EDTA in water as a cheap substitute for evaporust. One pound of EDTA will neutralize one pound of rust. It is safe enough that some people eat it. Keep everything fully submerged to avoid lines at the air water interface.
    Bil lD
  17. #16
    Mar 2003
    North Carolina
    1,589
    667
    262
    Citric acid works great. It's cheap and fast. My favorite is electrolytic but citric can be walked away from.
  18. #17
    May 2006
    Seattle
    2,531
    65
    665
    I drove all the way across the country once, stopping at feed stores and farm supply stores looking for the mythical cheap molasses. All I found were the pellets.
    Do you have a link where such molasses can be purchased?
    metalmagpie
  19. #18
    Feb 2010
    cleveland
    368
    13
    100
    I get both molasses and phosphoric acid at Tractor Supply. The phosphoric acid there is sold as Dairyland Sterosol Milkstone Remover 53% though.
  20. #19
    Nov 2006
    Southern California
    1,140
    11
    146
    Quote Originally Posted by metalmagpie View Post
    metalmagpie
    This is where I get mine:
    Molasses, 5 Gal
  21. #20
    Dec 2008
    Vt USA
    9,158
    1587
    3285
    vinegar and salt?
