Removing a stuck lathe chuck
Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Apr 2008
    Western Kansas
    5
    Default Removing a stuck lathe chuck
    I am trying to remove a very stuck 12 inch 3 jaw chuck so I can put a 4 jaw on and I can't budge it. I have done the easy stuff with cheaters and even put a big bolt in it and tried the 1 inch impact with no luck. I think the last time the thing was off was probably before 1971 so its been a while. Its a very old but very tight lathe and I am not real excited about putting heat close to the bearing but I am running out of ideas? The inspection date was 97 so I figure its probably bronze or some sort of babbit and since it is pretty accurate I don't really want to go down that road if I can avoid it.
    Thanks for any ideas.
    Oct 2013
    The Gorge, Oregon
    117
    26
    103
    Thread on chuck? Put a 1’ bar perpendicular in the jaws. Wack the end with a hammer.
    Nov 2013
    Utah
    2,594
    714
    1382
    I would recommend before you go doing anything more, post the Brand and Model of the Chuck here, maybe a picture.
    R
    Jun 2006
    Kansas
    1,131
    194
    269
    If your chuck has a removable back plate take the chuck off the plate turn the plate off the spindle, then make a new plate.
    Apr 2004
    Modesto, CA USA
    5,776
    860
    If the lathe was built in 1897 you are certainly correct that it has Babbitt bearings. You are not going to get it hot enough to melt babbit until the paint peels off and the grease/oil catches fire. Lead is something like 400 degrees. just warm it up to a warm cookie sheet temperature (350) to loosen the joints.
    By 1930 South Bend was steel on cast iron bearings. 1971 would be ball or roller bearing.
    Bill D
    Sep 2014
    72
    29
    20
    Don’t know what make lathe it is, dose it have a spindle lock?
    I wouldn’t use the back gears to lock the spindle, gears can and do brake.
    You may be able to wedge wood between bull gear and casting to lock spindle
    What kind of lathe is it ?.
  7. Likes partsproduction liked this post
    Apr 2007
    mays landing NJ
    444
    409
    116
    Try this, Chuck a large bolt in the 3 jaw. Use the largest wrench you have on the bolt head. I use a spud wrench or an 18" crescent wrench . Heat the back plate with a heat gun. The first time I tried this was with my own lathe. After about 5 minutes or so I pulled on the wrench and the chuck came loose with no effort.
    Second time was for a friend that bought an older lathe , I think it was a Logan , early 40's. This chuck seemed to be on the spindle since it was delivered. I tried the heat gun, wouldn't break loose. Soaked the back plate and spindle with PB Blaster. Waited til next day, then tried again.
    Finally I used a propane torch instead of the heat gun. This worked, chuck broke loose with some effort.
  9. #8
    Feb 2013
    North Carolina
    289
    414
    106
    Liberally apply penetrant soaking into the threads. As said earlier chuck a long steel or heavy wood bar perhaps five or so feet in length. You can whack it with a mallet or if that doesn't work hang some weight at the outboard end and leave it overnight. Chances are good the chuck will have loosened by morning. I've done this a couple times and it works.
  10. #9
    Jul 2002
    Maryland
    4,327
    621
    505
    There is a thread that addresses this problem that outlines a technique that has been quite successful for many.
    I was threading a chuck onto my SB and the garage phone rang, or some distraction, I forget. But lost track of what I was doing when I came back. The chuck was left almost threaded on, maybe a turn or two short. But I came back after the distraction and hit "power on". The "clunk" of that chuck as it was forced on I felt through the floor. Nothing I could do would loosen that chuck. Penetrating oil, applying heat, chucking hex bar and applying the impact driver, bar in jaws hitting with hammer... Nothing would even budge it. But using this technique it was removed and no harm to the gear train.
    Follow this technique. And if it doesn't work then turn off the back-plate when nobody is around to ask you why ...
    http://www.practicalmachinist.com/vb...torial-165028/
  11. #10
    Jan 2011
    New Brunswick, Canada
    1,509
    1628
    576
    Is this the thread you were looking for ?
    http://www.practicalmachinist.com/vb...28/index2.html
    Brian
  12. #11
    Apr 2004
    Modesto, CA USA
    5,776
    860
    Don't some lathe spindles have a threaded locking collar that has to be rotated to force the chuck off the taper?
    Bill D
  13. #12
    Feb 2008
    oklahoma
    22
    My chuck was stuck pretty good.
    Last thing I wanted to do was to lock up the bull gear. Teeth get pretty expensive when broken.
    Took a bar, put it between the jaws at a 90 degree angle to the bed
    Put a block of wood on the ways to protect them.
    Unlocked the spindle. No belts, no gear engaged.
    Repeatedly spun the chuck, with bar, against the block of wood on the ways. The momentum of the spin, and the relatively soft thunk against the wood, loosened the chuck in about 4 attempts. Didn't break anything either
  14. Likes HuFlungDung liked this post
  15. #13
    Jan 2012
    Midland, Texas
    1,345
    381
    683
    I cut a pair of slots on the back of the spindle to engage a piece of keystock. The keystock is held in an attachment I made that clamps to the spindle. The attachment has a two foot rod I can hold onto.
    I made a hex (square for 4-jaw) plate from 1/4" bar stock and cut a 1/2" square into it. I mount this piece in the chuck and put a 1/2" breaker bar into it. Turn the bars in opposing directions to unscrew the chuck.
    I'll add photos later, if I remember...
  16. #14
    Jul 2003
    savannah, jaw-ja
    1,546
    850
    316
    I'm with True Temper. Cut the backplate off and make another. Quicker than fooling around with all the other methods that may or may not work.
  17. #15
    Nov 2008
    Madera county california usa
    2,119
    19
    491
    No...
    Place the belted speed in the lowest it can go without back gear.
    Place a chuck key in and place it directly towards you.
    Get the biggest hammer you have and while applying tension down on the chuck key tap the key nearest to the chuck.
    The large hammer has a lot of energy that transfers well while small hammer needs large swing that breaks things.
    Also consider clamping belt together between cone pulleys to add brake power.
    This is process described in old manuals so it is "official" so to speak.
    Make sure you apply pressure to chuck key to insure everything is in contact so the energy is transfered to the threads.
    Sent from my SAMSUNG-SGH-I337Z using Tapatalk
  18. #16
    Mar 2010
    Davidson NC USA
    1,345
    443
    772
    Heat, applied with the biggest rosebud you can get. You will be surprised how long it takes to warm up your chuck, even a little. Heat the chuck until the spindle mount is hot to the touch. Then, all the above routines will work. Regards, Clark
  19. #17
    Jan 2006
    Aberdeen, NJ
    185
    23
    Don't force it. Use a bigger hammer!
  20. #18
    Apr 2004
    Modesto, CA USA
    5,776
    860
    Why do people here think it is threaded on?
    Bill D
  21. #19
    Feb 2008
    Illinois
    1,207
    53
    357
    I agree with previous post. If the chuck is threaded on, put the key in the chuck. No back gear. Hold your hand one the belt driven pulley and hit the key with a lead hammer. Sharp blow! No pussy footing! Done hundreds of times.
  22. #20
    Aug 2014
    bainbridge island
    805
    144
    203
    if the chuck is threaded on, evenly heat up the chuck until the spindle is warm.
    put ice cube in the spindle, apply torque immediately.
