Removing surface rust
Results 1 to 20 of 20
    Dec 2019
    AUSTRALIA
    78
    19
    Default Removing surface rust
    Recently purchased a mill that has had very little use but has been storage for approximately 15yrs. It has obviously had some form of preservative but there is some light rust on the table and other surfaces that I'd like to remove.
    What is the best method to remove light rust like this without damaging the surfaces? I have seen some used machines for sale that have been wire buffed but am unsure if this would cause any damage
    Sep 2007
    Cairns, Qld, Australia
    2,885
    1009
    821
    Quote Originally Posted by NewGunPlumber View Post
    Steel wool is non abrasive is generally accepted for this and will need some elbow grease to work but won't cause damage to the iron itself.
    Jan 2005
    The Netherlands
    6,800
    378
    2019
    Scotch brite with phosphor acid
    Over her we have toilet cleaners which work for rustremover it says on the label
    They contain pfosphor acid with some inhibitors that make it work better it says
    Neutalize with some detergent Dry and then inmediatly apply some oil
    Peter
    Aug 2017
    347
    98
    172
    Evaporust for anything that fits in the bucket, razor blade for anything flat, wire wheel for everything else.
  5. Likes dalmatiangirl61, 52 Ford, Janderso liked this post
    Feb 2014
    FL
    4,492
    13835
    5469
    May 2021
    Virginia
    168
    203
    48
    Quote Originally Posted by jwearing View Post
    I second using EvapoRust. That stuff is like magic. I think there's a gel version you can brush on like paint stripper. I haven't used it, but I imagine it's worth a shot.
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  8. Likes dcsipo, richard newman liked this post
  9. #7
    May 2021
    Virginia
    168
    203
    48
    Here's a link to that EvapoRust Gel.
    Amazon.com: Evapo-Rust GEL Rust Remover Removes Rust and Rust Stains from Most Surfaces, 8oz: Automotive
    I think Home Depot and Lowes sell it, too.
  10. Likes richard newman liked this post
  11. #8
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,156
    3132
    1973
    Quote Originally Posted by 52 Ford View Post
    The OP is in Australia, according to another Aussie poster E-R is not available at a reasonable cost there, so he might be better off doing an electrolysis tank. For large flat surfaces a razor blade is the way to go.
  12. Likes 52 Ford liked this post
  13. #9
    Jun 2020
    Ohio
    118
    33
    38
    Evaporust works well on larger surfaces too. Soak a paper shop towel in it, lay it on the surface then cover it with a trash bag. Make sure the paper towel makes good contact with the surface. You can lay or lightly clamp something on to hold it against the surface.
  14. #10
    Dec 2019
    AUSTRALIA
    78
    19
    Yeah no joy with evaporust over here. Its very minimal so might just try some steel wool / scotch bright and use a bit of penetrene to help break it down and see how it goes.
  15. #11
    May 2020
    Minnesota
    489
    194
    189
    Any light oil and a brass brush. Soft steel wire wheels are often okay as long as you keep them away from non-hardened precision surfaces. Handwheels, ball cranks, hardened gear teeth, etc.
    Consider a penetrating oil like Kroil for dissolving preservatives and waxy residue in conjunction with the action of the brush.
  16. #12
    Apr 2004
    Modesto, CA USA
    8,708
    1685
    EDTA and water is the basic ingredient in evaporust.
    Bill D
  17. #13
    Jan 2007
    N. Virginia
    60
    5
    You could also use vinegar, it's not fast but does work well. It won't remove paint.
  18. Likes Janderso liked this post
  19. #14
    Dec 2008
    IL/WI border
    3,537
    1282
    1105
    Phosphoric acid is cheap and widely available. Usually, they sell it in hardware stores as a concrete cleaner (or etcher) or "phosphoric prep" for metals and concrete, and it can be used "as is" or diluted 2:1 or 1:1 with water (I usually use 2 parts of acid to 1 part of water).
    I like Evaporust and used it very often, but nowadays I almost completely replaced it with phosphoric acid. The results are virtually identical, and the acid works quicker.
  20. #15
    Feb 2010
    ch
    3,345
    277
    467
    hm, in my experience phosphoric undiluted will not do much. it needs water. i use a solution of around 15-20%.
  21. #16
    Dec 2008
    IL/WI border
    3,537
    1282
    1105
    Quote Originally Posted by dian View Post
    I'm sure what they sell in OUR hardware stores is already diluted acid. In any case, it works "as is" very well. But further dilution makes it more economical without any noticeable drop in efficacy.
  22. #17
    Jul 2006
    rochester, ny
    2,361
    593
    763
    I really like Evaporust, especially that it doesn't eat any steel even if the part is left in for days. Can't remember, does plain phosphoric go after the steel if left in too long. Definitely happens with citric acid.
    Glad to learn about the gel, just ordered some, seems like it will be very useful.
  23. Likes 52 Ford liked this post
  24. #18
    Feb 2004
    peekskill, NY
    27,271
    6347
    All very interesting, can anyone tell me how remove *subsurface* rust?
  25. #19
    Apr 2004
    Modesto, CA USA
    8,708
    1685
    Quote Originally Posted by TeachMePlease View Post
    Can you do this on painted wood?
  26. #20
    May 2021
    Virginia
    168
    203
    48
    Quote Originally Posted by jim rozen View Post
    I've have pretty good luck finding all the hidden rust in cast iron when I weld it. Removing surface rust
