LowEnergyParticle
Cast Iron
- Jul 26, 2004
- Beaumont, near Houston
I'm repairing an old Reilang #3 single-pump oiler that I bought at auction. For too much. Moisture got inside the oiler and corroded the spring and both check-valve ball bearings. It was pretty filthy when I took it apart, and like an idiot I didn't look carefully at the two ball bearings that act as check valves on the suction (bottom) and discharge (top) of the oiler. Once I cleaned the ball bearings, I found that they were different sizes: 5.5mm and 6.0mm. Whoops. The oiler seems to work with either ball bearing in either position. I'm figuring that Reilang's smarter than me, and they wouldn't have bothered to use two different size ball bearings without a good reason.
Does anyone know which ball goes into which position?
Thanks!
Dave
Thanks!
Dave
