Repairing stripped extral threads
Results 1 to 5 of 5
    Aug 2017
    6
    Default Repairing stripped extral threads
    Wanted to see what methods if any I can try on this part to repair the external threads. The threads on a 1" steering stem from a Harley front end are stripped in the middle. The stem is welded in and removing it would mean re-chroming which I am really trying to avoid.
    The portion of the threads that are stripped is where a thin nut that preloads the tapered neck bearings go, then a top clamp goes on over that and another nut at the top.
    Do people ever lay down small beads with a welder and run a die over them?
    Pics below
    Aug 2006
    Virginia
    568
    783
    335
    Not sure I’d invest a lot of effort repairing that. It is one of the most critical components on a motorcycle. I would just replace it.
    On a display bike, historical value, a weld up and re thread would probably work but the HAZ and weld hardness would cause me issues...
    Joe
    Jan 2013
    Plainfield, Indiana, USA
    1,650
    1221
    871
    Make a thin walled 'spacer' about 3/8" long to put between the nut and top clamp which moves the nut to good threads. If need, chrome the spacer.
    Aug 2002
    West Unity, Ohio
    24,193
    4343
    7144
    ... and maybe a thicker nut next time!
    Think Snow Eh!
    Ox
    Nov 2008
    Madera county california usa
    2,290
    20
    554
    Make a new nut that includes the sleeve or that is just taller.
    Make a bit undersized to insure less slop.
    Also get a thread file to clean up what is left.
    Longer area of engagement needed here.
  6. Likes Pathogen liked this post
