skipd1
Cast Iron
- Jan 6, 2010
- Bismarck, ND
I have acquired a Biax power scraper and after finding out the prices of replacement blades I have decided to make some for myself. I want the 150mm length blades and I will braze on carbide blanks and radius them. However I do not know what type of steel they are made of and the thickness and width they should be. Can they be made out of mild steel or does it need to be tool steel. Also I have noted that the 150mm blades are thinner than the short ones I have and thinner than the blades with the indexable insert heads.
Any advise or dimensions would be greatly appreciated.
Skipd1
Skipd1
