Requirements for surface plate support? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    Feb 2010
    ch
    2,093
    194
    274
    if you know the topography of the plate, you might want to "customise" the way you support it. e.g., if the plate is like a mountain, you wound support it on the corners.
  2. #22
    Jun 2016
    Virginia
    909
    465
    109
    Quote Originally Posted by dcsipo View Post
    Was the crappy room built around the plate?
    dee
    ;-D
    That room is one of the best in that old building. BTW the little white signs read: "This tool must be returned to the inspection bay at the end of each work day Mon-Thurs and by noon on Friday."
  3. Likes dcsipo liked this post
  4. #23
    Aug 2007
    Wisconsin
    2,061
    1075
    918
    That looks like Ted's plate over at Marena Industries. He has a nice shop.
  5. Likes Cannonmn liked this post
  6. #24
    Oct 2014
    Maryland
    2,420
    1738
    1845
    Quote Originally Posted by Cannonmn View Post
    i buy that...it just seems like there is no way to put the plate into the room, must have built it after the plate was in place
    dee
    ;-D
  7. #25
    Aug 2007
    Wisconsin
    2,061
    1075
    918
    dee
    ;-D
    My guess is he got the plate in this room, you should see how the way grinder is shoehorned into the shop!
  8. #26
    Apr 2004
    Modesto, CA USA
    6,663
    1095
    I understand the theory of the airy points but I have to ask shouldn't they be the same orientation as from the factory. In other words the single point at one end and the two other points should stay at the same end of the plate as they came from the factory. I would think reversing which end has which support might cause some bending of the plate so it was no longer in calibration.
    Bill D.
  9. Likes Spencer in NH liked this post
  10. #27
    Jun 2016
    Virginia
    909
    465
    109
    Quote Originally Posted by cash View Post
    And these days vertical turret lathes spring up anywhere there's just enough space in the old building.
  11. #28
    Jun 2008
    Bellingham, WA
    3,895
    930
    2035
    Quote Originally Posted by Bill D View Post
    Bill D.
    While in a perfect world airy point supports would be placed exactly as they were when the stone was (re) certified, as It is necessarily true that any stone must sag some due to its weight, that sag may not actually measurably affect stone surface trueness when the stone is not heavily loaded with additional parts and equipment. Using airy points oriented "north-south" may be of equal practical benefit to the same stone if oriented south-north. This can be confirmed by beam stiffness calculations and probably underlies thickness vs length standards as published for surface plates. (I tested this stiffness question with a metrologically well-equipped friend using a couple of plates in my shop which we checked when airy-point supported and then when propped by one corner and one edge---the anti-airy-point method. Despite good equipment and technique we could not measure a difference.
    Where airy points may shine is when you place on the stone a piece of equipment that weighs a significant portion (pure guess of 10 to 20 % minimum of stone weight) on the plate. Then airy point support diminishes the total span between supports and thus diminishes plate distortion due to load bearing. So, exactly reproducing initial support points may not be as important as using some airy points of whatever orientation.)
    I would love it if someone reproduced the experiment we did in my shop and reported either confirmatory or contradictory results. "Science" becomes more credible with repeated testing and becomes more credible with several independent confirmatory observations.
    Denis
  12. Likes cash liked this post
