Resurfacing Aluminum Cylinder Heads on a Bport Mill? 50Ra surface?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 84
    Feb 2011
    BFE Nevada/San Marcos Tx
    3,500
    3441
    2202
    Default Resurfacing Aluminum Cylinder Heads on a Bport Mill? 50Ra surface?
    A friend works on Subaru cars, Subaru only. Her bread and butter is cylinder head jobs, she tries to keep rebuilt heads on the shelf ready to go, but the good rebuild shop has a 2 month lead time, and they are banging her for $350 a set. She tried another shop recently but whatever machine they are using cannot cut a smooth enough surface and they leak with a basic pressure test after installation. The gasket manufacturer is telling her the surface finish needs to be 50Ra or better.
    She would like to start rebuilding the heads herself, so the question is can a 50Ra surface be achieved on a Bridgeport style mill? Heads are 10" long x 8" wide, so I don't think table rocking would be an issue.
    Apr 2018
    10,386
    5015
    Quote Originally Posted by dalmatiangirl61 View Post
    ...can a 50Ra surface be achieved on a Bridgeport style mill?
    Don't know about a Bridgeport but a Gorton would have no problem
  3. Likes 4GSR liked this post
    Feb 2011
    3,500
    3441
    2202
    Quote Originally Posted by EmanuelGoldstein View Post
    Yeah, well she can't have it. I know I can make a nice pretty surface, but never owned a profilometer to test how good it was, forgive me lord, I have sinned. I get to do the shopping for her, just want to make sure it is achievable before I spend her money. The heads are so small you could surface them in a lathe, fixturing them to the faceplate would probably be a pia though.
  5. Likes 4GSR liked this post
  6. #4
    Nov 2018
    Minnesota
    247
    160
    124
    If the spindle is tight, use a pcd insert flycutter. Jamison equipment sells them for a bridgport if you want to buy it or making one isn’t a big deal finish will look like a mirror if you want
    When I find it I don’t need it
    When I need it I can’t find it!
  7. Likes dalmatiangirl61 liked this post
  8. #5
    Jul 2006
    Hillsboro, New Hampshire
    14,860
    3236
    9911
    Unless you can find a nearly-new machine that's not been beat on, I'd worry that a BP will rock unacceptably, even over just 15" or so. Remember, you have to add the diameter of the flycutter or whatever she'll be surfacing the head with to the travel distance, and the table support is so short that it doesn't take much wear to give significant height changes.
    Maybe look for a used bed mill? Not nearly as common, but probably a better choice for head surfacing. Like this, except manual (unless there's serious money to throw around): TRAK Toolroom Bed Mills featuring the ProtoTRAK RMX CNC
    Just be sure to lock the Y axis before use.
  9. Likes dalmatiangirl61, DJ2, cpifer3 liked this post
  10. #6
    Apr 2018
    10,386
    5015
    It's not as good but there are electrochemically etched sample plates for various surface finishes that give you a pretty good idea. Supposedly your teeth are more accurate than your fingernails (if the part is small enough, might be embarrassing to get caught nibbling on a Buick bumper )
  11. Likes TheOldCar liked this post
  12. #7
    Oct 2007
    SPAIN
    6,392
    2371
    1265
    It'll be a piece of cake.
    Facemill - I always used a 60mm dia 90deg insert, but the geo was double positive.
    Axial and radial, to allow for cutting through hardened valve seats on certain makes.
    I just googled Scoobys and they're sunken, so all you're cutting is ally.
  13. #8
    Oct 2007
    SPAIN
    6,392
    2371
    1265
    Rubert blocks
  14. Likes boslab liked this post
  15. #9
    Jun 2002
    CANADA
    British Columbia
    3,411
    3455
    Hi dalmatiangirl61:
    I've never done Subaru heads but I've done Mazda heads and I did them on my surface grinder.
    I had a 10" x 20" Kent grinder and it did a perfect job...flatter than flat, and way better than 50 microinch.
    I found it easier to do on the grinder...easier to fixture and easier to control the DOC and the flatness within close limits.
    I slathered the head with Relton A-9 aluminum cutting fluid before each pass and ran a 46J standard aluminum oxide wheel.
    Came out perfect and didn't take very long at all...maybe 15 minutes per head? (it's a LONG time ago).
    So if your friend is considering tooling up for this, she might want to consider a grinder instead of a mill.
    Only problem is, grinders are not very versatile in a normal shop, whereas a Bridgeport can be used for a gazillion things.
    Cheers
    Marcus
  16. #10
    Feb 2011
    3,500
    3441
    2202
    I pulled up the link below, I'm going to assume now she meant .50Ra , she said the heads that leaked had the roughness of vinyl LP's.
    Surface Finish - Destiny Tool
  17. #11
    Oct 2005
    dexter mich
    332
    14
    86
    the answer in my book is get a lapping plate much bigger than head and lap it flat This is the best way to take least possible of heads you need to block out plate to get even wear A cutter that does not cover hole head will likely leave lines were the 2 or more paths cross A lapping plate will not Use kerosene or gasoline with oil with the lapping compound
  18. #12
    Aug 2007
    Idaho
    3,178
    1766
    2131
    I think there is a head surfacing machine in a cheap or free pile just over the mountain from you in San Andreas CA, gunsmith there got a good deal on a shop with one and took it home, I don't think he has any use for it. It kinda looks like a tiny bridgemill with a giant shellmill in it
  19. #13
    Oct 2007
    SPAIN
    6,392
    2371
    1265
    Quote Originally Posted by Ken hosford View Post
    If the heads have blown through water damage which is quite often, 4 to 8 thou to clean up is quite common.
    That's a crap ton of lapping.
    My process was I could do a head from bare table to bare table in 20 mins - it was a good earner but I was geared up for it with different clamps, paired/matched parallel blocks to sit the head on etc.
    After skimmming and still clamped, hand csk all holes and then scotchbrite the edges to take the sharpness off/deburr.
  20. Likes TheOldCar liked this post
  21. #14
    Sep 2008
    2,792
    2096
    1729
    If it's 8" wide that means you need min 8.25" diameter (or more) flycutter. and if the heads 10" long then your going to be traversing 18.5" in X, so unless it's a brandnew BP it's going to rock. And then there's the issue of tramming the head perfectly so the flycutter doesn't create a dished surface.
  22. Likes dalmatiangirl61, CarbideBob, DJ2 liked this post
  23. #15
    Dec 2008
    Vt USA
    9,945
    1828
    3738
    Modern head gaskets do not want a smooth surface. They want a surface that is "just right" for the sealing materials and technology applicable.
    We may note that 50Ra is very coarse indeed. and that is my experience. Lapping, as we may think of it, is strictly OUT unless you are running the work over Black Beauty blasting slag.
    I'm sure a BP could do the job. Motorized table feed for controlled rate. Better might be a Blanchard.
    ETA
    Consider, It will be the TRAILING cut that produces the surface finish when using a fly cutter or face mill.
  24. Likes Chrisw liked this post
  25. #16
    Feb 2011
    3,500
    3441
    2202
    Quote Originally Posted by kustomizer View Post
    Do you have a link or contact info? Friend is in Texas, maybe I could get her to haul a load of stuff out here for me in exchange for a surfacer
  26. #17
    Mar 2003
    Vermont
    540
    134
    154
    In northern New England, Subaru may be the most popular brand. Head gasket failure on older models such as the 2.5 was near 100% by 120K miles. On one of my cars was able to lap the head flat using a granite plate with sheets of 230 grit lapping film. Several years later was running trouble free. Objective being, aluminum heads move a lot between -20 deg and 210 deg. Critical the head gasket tolerate creep. Being flat within .0005 and a fine surface finish best accommodates that that. Following the gasket manufacturer's guidelines is a great starting point.
    How To Clean a Cylinder Head Mating Surface | Fel-Pro Gaskets
  27. #18
    Feb 2011
    3,500
    3441
    2202
    Quote Originally Posted by CalG View Post
    ETA
    I'm thinking she meant .50Ra, waiting for her to confirm.
    Edit: I'm confused, the Destiny link in post 10 says 50Ra is "rough cast", yet the Felpro link in post 17 says to finish aluminum heads to 50-60Ra??????????
    Edit again: OK, I see there are 2 Ra scales on the Destiny chart, Ra um and Ra micro inch, I'll have to learn the difference.
  28. #19
    Dec 2008
    Vt USA
    9,945
    1828
    3738
    It will depend on the gasket technology. Check it out. "creep" is the killer these days.
  29. #20
    Aug 2007
    Idaho
    3,178
    1766
    2131
    I just called him, he sold it not long ago, he still has a belt sander type and a surface grinder, both big enough for this job I would imagine but the other would have been perfect. Sorry
  30. Likes dalmatiangirl61 liked this post
