Wlodek
- Nov 15, 2018
Roller burnishing is mostly found in production, but can be a useful process in any shop. Production tools like this are expensive, and the cheap one are...cheap. Accurate and constant pressure force is essential in getting good results, and force indicator desirable.
Having little more time now that I am semi retired I've decided to design and built one. The design is a simple, a one piece tool that can provide adjustable pressure without sliding parts that are prone to binding. It has, as well, a force indicator in the form of a re-calibrated dial gauge. The tool is made out of heat treated D2 steel and was designed (using simulation) to provide a force of 0-600 Newtons (0-135 pounds-force) with a deflection of 1mm indicated on the dial indicator (one revolution) at the back of the tool. The burnisher wheel is a ball bearing with the outside race edge rounded and polished. Pictures show the design, the simulation and the tool in use. I hope this design can be useful for those contemplating to build one.
