Hello! I've been lurking around here a while reading in my spare time. First post today, looking for some advice from the much more experienced members here.
Background... I do my fare share of fab work in my garage. Custom parts for my car, BBQ grill, trailers, and quite a bit of stainless TIG for work related items. I have a nice tight Bridgeport that I play around with, a Walker Turner bandsaw, MIG, TIG, plasma, etc... I have some tooling for the mill, but I am in NO WAY a machinist. Rook-dawg looking to learn.
We have some parts at work I'd like to produce. Some pictures below.. These are high pressure junction blocks rated at 101,000 psi. They are made out of HP160 which I cannot seem to find anywhere. Its a special alloy for this industry - however I have some other parts that are rated for the same pressure made from 15-5 stainless.
HP160 has a tensile strength of 160,000 psi
15-5 in the H1025 condition has a tensile strength of 155ksi... pretty close. Rockwell is at C35 for this stuff.
Have a look at this part... I need to mill a flat bottom hole and thread it 3/4 - 16. Threads DO NOT have to go all the way to the bottom.
Also need to have the cone feature in the bottom that the high pressure tube seals into.
Any recommendations on how to produce this feature on my Bridgeport?
Can I thread a hole this size in C35 material using a Tapmatic?
Do I use an end mill and keep stepping up in size until I reach the correct diameter, or do I use my boring head?
Like I said, I have very little machining experience but would love to learn. With what we spend on these parts I could easily justify the purchase of a new HASS Mini... but I'd like to get started without dropping $35k on a machine.
Thanks for any input or advise!
