swarf-sweeper
- Jan 17, 2007
- Kansas City
Hello All,
My 7 year old RPC stopped working early this week. Its a 7.5 HP RPC that I use to run my Lathe & Bridgeport Mill.
When I flip the switch, all I hear is a loud humming sound coming from the idler motor. My first thought was one or more of the start capacitors must have gone bad. So, I pulled the cover off the converter and found where two of the 3 start capacitor's had been leaking with crusty stuff coming out of one end of it. I just got through replacing both capacitors with exactly the same spec replacements -- no dice. Still hearing a humming sound.
There are only two other components in this converter -- 2 tin covered Run Capacitors and a Relay Switch? Could the problem be in the relay or run capacitors? Or is the problem specific to the idler motor? With the power off, i was easily able to turn the motor by sticking a screwdriver through the vent hole in the end so I know the problem isn't due to the motors inability to turn freely.
Any ideas on how to troubleshoot this are greatly appreciated!!
-Swarf-Sweeper
-Swarf-Sweeper
