G
guest
Guest
I'm about to start a project that uses a lot of .250 wall 6061 tubing. I'll use sizes from 1-1/2" to 6".
I have some 5' long pieces of tube that I will not be using- planning to order everything already cut to length.
Looking at the material on hand, the 1-1/2", 2", 3", and 4" tubes are right on size (+/- .003). They are Kaiser and Sierra, and stenciled ASTM B429. The 5" is oversize by .050"-.090" and egged out. This material is from Service Center and stenciled ASTM B221-14.
I know the association standard tolerances for extruded materials, and the 5" is outside that tolerance.
I don't know what a 5" pipe would be on the OD, I'm hoping this is just a pipe spec and not a tube spec.
Also wondering- is the B429 spec a tighter tolerance than the B221? I'm about to order a bunch of this and my supplier is quoting ASTM B221 on the smaller sizes too.
Would like to avoid a clusterf*ck of 800+ pcs. of tubing that don't fit...
