Rotate a round part in vice
Results 1 to 18 of 18
    May 2015
    6
    Default Rotate a round part in vice
    I'm interested in techniques for how to drill holes at different angles in a round part.
    Like say I want to drill a hole and then drill a perpendicular hole.
    There's some ways I could do this if I had special tools. If you have a super spacer it could get chucked up. Maybe an indexing head or rotary table would work the same way but I've never tried that.
    I could also use a 5C collet if it was small enough to fit in there.
    I've also had people print out the holes on a piece of paper and then wrap the paper around the part.
    I've also tried making parts radially and transferring them to the axial part.
    Is that all the ways or is there another way?
    Mar 2005
    Kansas
    8,570
    591
    4311
    If the part is sufficiently long, clamp a vee block to the shaft. The vee block hangs out in the air. Use a square against the side of the vee block for orientation. Some vee blocks will allow the part and clamp to be inside the height of the vee.
    A simple scribed line on the end of the part may suffice. Scribe the line and drill the first hole. Now rotate the part and use a square to align the scribed line.
    Put a dummy pin in the first drilled hole and check for alignment after rotation.
    You always have the right tools. You just gotta know how to use them.
  3. Likes Bobw, paulz, 72bwhite, sfriedberg liked this post
    Oct 2005
    21,607
    Quote Originally Posted by jfenwick View Post
    You have not indicated:
    1. size of part
    2. holes and location (and tolerances)
    3. Machinery at your disposal
    So I will suggest qty (1) tool that will, in fact, drill any number of holes, in any size part,
    in any location:
    3/8 in. Variable Speed Reversible Drill
  5. Likes Mtndew liked this post
  6. #4
    Sep 2004
    Sonora , Calif
    627
    122
    131
    Default Does round mean like a ball or like the od of a piece of round stock?
    1. size of part
    in any location:
    A sketch of what you want would help understand guestion.
  7. Likes digger doug liked this post
  8. #5
    Sep 2010
    Oklahoma City, OK
    5,485
    1059
    2392
    Big stuff, like a pressure vessel, is laid out with a square, level and tape.
    I use the level vee block for small stuff.
    Sent via CNC 88HS
  9. #6
    May 2005
    AZ
    2,508
    250
    857
    As Digger Doug notes, the substance of your question is vague, as the actual part requirements and equipment available will dictate the methods that can be used in any given situation.
  10. Likes digger doug liked this post
  11. #7
    Mar 2009
    6,118
    116
    1201
    I use collet block chucks. Traver is just an example. Don't expect made in USA. Taiwan is the best you can hope for...
    You can do 60, 90, 120 degrees. Modifications or copying the base and make new angles available.
    Collet Block Chucks For 5C Collets | 49555 | Travers Tool Co., Inc.
  12. #8
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    4,049
    109
    972
    Just clamp something square to it .index .
    it will not make it a virtue though.
  13. #9
    Virginia
    19,710
    7561
    11850
    Quote Originally Posted by gbent View Post
    ^^^ THIS ^^^
    Take a medium-sized, cheap, even used imported, Vee block.
    Take the time to put a fair-sized hole right through the sharp point of the vee.
    Buy or fab drill bushings. Good ones, hardened for "many" ohles aren't rocket science to fab and harden. One-time use need not even be hard.
    Come at the round from the BACK of the Vee block.
    And for years and years thereafter, you can do the do even outdoors in the ditch with portable hand drill motors and a bit of Ell angle chained to or clamped on for the guide to index for the next hole.
    Play with the concept. With wood, even. You'll get it.
    Wuddn' yah know it?
    Folks even sell this kinda stuff. A decent CI one will just last longer than shiddy pot metal!
  14. #10
    Feb 2014
    FL
    4,308
    13559
    5134
    Quote Originally Posted by rons View Post
    Hardinge will make 5C collet blocks in the US, as a special item. Don't ask me about price, though.
  15. #11
    Sep 2015
    Ohio
    1,772
    1170
    1892
    I had a job where I had to drill 11 holes equally spaced around the OD. Not really conducive to any kind of indexer.
    I had a CNC mill so I took a round slug and milled 11 equally spaced flats on it, bolted the part to the face and used the flats to register off of.
  16. #12
    Nov 2014
    Florida
    6,248
    2486
    3098
    Full 4th axis? Make them eleventy seven degrees apart if you want. Every part will be the same.
  17. #13
    Feb 2004
    peekskill, NY
    26,864
    6182
    Unfortunately, given your stated tolerances, there is currently no way to drill holes to that degree of angular precision.
  18. #14
    May 2010
    Cambridge, MA
    1,786
    78
    1037
    Maybe read a book about drilling holes in stuff?
    Oh wait, I forgot that there are no books in California.
    Once I was being given a tour of Google's campus in Mountainview and when we were going through the areas where the junior programmers worked, I noticed that they were just sitting at open tables with no space between them and there were no bookshelves anywhere. So, I ask the Chinese girl who is showing me around, "Where do the programmers keep their books?" and she responded, "Why would you need a book?" Welcome to California.
  19. #15
    Jun 2016
    New York
    2,140
    1717
    1051
    Quote Originally Posted by Booze Daily View Post
    11? no problem for a typical geared dividing head, just need the right hole plate. a dividing head is an "indexer" just not a "direct indexer", and there is no reason a direct indexer can't have an 11, 22, or 33 hole pattern, its just not common.
    you made you own direct indexer, in fact nice work, cheers!
  20. #16
    Nov 2003
    5,918
    210
    2039
    Those collet blocks are the first thing that comes to my mind. But, of course, you are limited to ones with 4 or 6 sides for multiples of 60 and 90 degrees. And, of course, you will need to have (buy) a set of collets.
    The good old, spin indexer also comes to mind. With this device you can index in multiples of one degree. That gives you a lot more numbers if you are evenly spacing your holes. Five would be the first number that comes to mind, but others include 8, 9, 10, 12 and more. But some low numbers are still missing, like 7.
    Next would be an indexing head or a rotary table. But with the indexing head you need a good set of plates with different numbers of holes in their circles. Most rotary tables will have a hand wheel that is calibrated in degrees with a Vernier that will reach down to the level of arc-seconds. You have to do the math. Either of these methods could be used for any number of divisions if you have the proper hole circle plate or do the math. And the accuracy can be the highest short of using a sine bar.
    A sine bar will allow any angle with great accuracy but will require a flat feature on your part or some kind of straight edge clamped to it.
    And there are tricks. A pin in the first hole can be aligned parallel to the table to drill a second hole at 90 degrees. But drilled holes are not all that exact and a pin can wobble in one so a lot of precision is not possible. A level with vials at 90 degrees to each other could be attached to the part so that one level vial is indicating horizontal. Then rotate until the second level vial indicates level.
    If your part has a flat feature then it can be used against a square that is sitting on the table. This would be good for multiples of 45 degrees with most squares. Plastic triangles intended for drafting could be used for multiples of 30 degrees. Depending on the size of that flat feature, this method could get the accuracy down to a few arc-minutes.
  21. #17
    May 2017
    Massachusetts
    341
    21
    96
    Quote Originally Posted by TeachMePlease View Post
    I think the Hardinge ones are mostly pneumatic or hydraulic, so a little trickier to rotate.
    https://www.shophardinge.com/categories.aspx?catid=25
    Most of the Harding ones are made by Lexair by the looks of them: Lexair, Inc. Pneumatic and Low Pressure Hydraulic Collet Closers
    I use 3c Lexair blocks for holding parts during manual assembly at work.
    Another option in this class is Compact Automation: Catalog - Browse
  22. #18
    Feb 2014
    FL
    4,308
    13559
    5134
    Quote Originally Posted by newtonsapple View Post
    Nah, I got on with their live chat and asked them if they made manual collet blocks for 5C. They said they'd happily make them as a special. I can get you a quote, if you like.
