Round Tube to Square Tube-- Possible Processes - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    Oct 2005
    18,880
    Several post's are saying "not enough info" and I concur 100%
    Surprising how an "engineer" would leave out the details.
    I suggest explosive forming.
    Hopefully there will be some failures along the way.....
  2. Likes Rudd, Limy Sami, Illinoyance liked this post
  3. #22
    Jun 2019
    Missouri
    290
    150
    177
    Quote Originally Posted by GregSY View Post
    It's very possible and very feasible if you use the proper material. Normal steel? No way. But gold? Easy. Gold is very malleable and can be formed in this manner. I'd use gold.
    Wow.
    Tough room.......
  4. #23
    Jan 2007
    Norfolk, UK
    20,252
    15652
    16045
    Quote Originally Posted by Thunderjet View Post
    Wow.
    Tough room.......
    Another one who doesn't know professional machinists
  5. #24
    Jun 2019
    Missouri
    290
    150
    177
    Quote Originally Posted by Limy Sami View Post
    I deal with them EVERY DAY.
  6. #25
    Jan 2007
    Norfolk, UK
    20,252
    15652
    16045
    Then you'll know this isn't a tough room - won't you
  7. #26
    Jan 2007
    New Jersey
    1,084
    594
    589
    Well, I needed some humor early on a Monday.
  8. Likes Limy Sami, TeachMePlease liked this post
  9. #27
    Aug 2006
    Cape Cod, Ma
    487
    222
    118
    Mcmaster you can get it in .06 and .08 wall by the foot.
  10. #28
    Jun 2012
    Michigan
    12,131
    4097
    4348
    Some one mentioned gold..Get .060 wall 1 1/4 square x 12" and fill it with 24 ct gold to make it more solid and if it doesn't get lost in the mail I will grind it to size for free..... better than free I will give you 20 bucks for giving me the job.
    Why is the wall thickness that important? is it the weight ?
  11. #29
    Nov 2003
    5,522
    189
    1868
    It seems that you can get it. But if you are really intent on making it from round tube, I would make some comments. Full disclosure: I have never done anything like this and probably never will.
    1. Start with something closer to your final size. Like 1" or even 1.25" diameter round tube. That will save a lot of work and many failures.
    2. I would probably make a set of several internal mandrels so the transition can be gradual, not all in one step.
    3. Heat would probably be very helpful. It will soften the tube for the stretching and it will relieve the stresses after each step, making the likelihood of a crack less.
    4. You need only one foot. I would have at least ten feet of stock as there will probably be multiple failures.
    A better approach to making it would be to have two one foot lengths of 1.25" angle and weld them together. You can run a mandrel down the center for final size if needed.
    If you are thinking this will save some money as compared to just buying it, it won't. Have fun.
  12. #30
    Jun 2012
    Michigan
    12,131
    4097
    4348
    One could send round stock to the steel mill melt it down and with that mix run some square tube to your liking.
  13. #31
    Oct 2017
    611
    164
    173
    1- Form it from sheet
    2- Oblong a tube in a press, build a channel of the appropriate size and force the tube into it in a square cross section. It may buckle weirdly
    3- Draw it over a square mandrel
    4- Compress it with rollers. A shop near me does this to make railing shapes from standard tubing.
    5- Explosion forming (as mentioned)
    6- Machine from billet
    7- Cast it
    8- Use an electromagnetic pulse to compress it around a square mandrel
    9- Wack it against a tree until it's square
    10- Design your project to use available materials
    Some are more practical than others.
