rust protecton for new machines
drcoelho
Stainless
Feb 19, 2017
Los Altos
Looking for recommendations for light oil to protect machine surfaces on my lathe, manual mill, etc....one recommendation was Lube-All. What do you recommend?
Not that I've ever bothered with a machine, but used lanolin for bits and pieces that will sit for a while post machining to prevent rust, it's cheapish....if not sheepish!:D
LPS-1 is an alternative to Starret M1.
LPS-3 leaves a sturdy waxy coating. Not hard to clean off (like cosmoline) and easier to apply than anhydrous lanolin.
Constant use is best!
Got a shop full of iron not far from your location and to be true, never bother with "protective" coatings and don't have rust issues.....even in the winter...Just wipe things down when finished, being careful to not remove
oil from sensitive surfaces.
Its a climate thing.....Relatively low humidity and warm temps here.
LPS3 is best for long term storage, so when shipping parts to places where the climate is less favorable or outside storage...
Cheers Ross
I found that a "Fluid Film" work well. It is lanolin based.
I looked the MSDS up. It's basically lanolin in kerosene, or maybe something slightly lighter. Lanolin is the traditional rust inhibitor used in marine applications of multi-stranded galvanized wire rope. Look in books on marine rigging for recipes.
CRC 3-36 is great stuff and is surprisingly good at preventing rust. I was skeptical but after it dries it leaves an extremely thin protective layer that even works on vise anvils in active northern garages. It usually has a dye in it (different colors avail), so you can verify coverage. It is very thin, and so it sprays and wicks extremely well. Gallons are cheap. It is very toxic to aquatic life, so it isn't exactly benign.
If you like to smell like ground up rotting sheep, otherwise I would say it is a big no for actively used machines. It has some great features for machines in storage. Especially on cold machines, in cold application conditions. It does stay wet and goopy, so it is fairly "self healing" on a machine, meaning a scratch or void in coverage (like from a cover) will tend to fill in over time. It also does not require much in the way of surface prep. It is cheap by the gallon and I slather it in with a big paint brush. I see people often suggest it is non-toxic or natural in some way but even applied with a paint brush in the cold, it chokes up my lungs and throat pretty good, so I think those claims are BS.
LPS 3 is great, but it is not suitable for machines in active use and the application requirements for good long term protection are somewhat involved and particular.
Yep that's the stuff. I bought an aerosol can to try it. Used it twice now it's on a shelf by itself and I'm hoping all the gas leaks out before I'm tempted to use it again.
My shop manager uses it to winterize his vehicles, buys gallons and sprays it on the underside of his trucks, it seems to do that well.
Gibbs is pretty good too. Hot rod guys use it to seal up magnesium wheels after being polished.
M1 is largely petrolatum in solvent with a few additives. I tried to figure out what it is in order to duplicate it on the cheap because we buy it in pails and sometimes dip finished parts in it but haven't been able to. The effect is like a micron thick layer of Vaseline. We make parts with pointy teeth and other features that make them real hard to clean, so we tested all sorts of preservatives to avoid staining and laborious cleaning after storage and we've settled on M1. Tried a few others since, hated the vapors, went back to M1. I've seen a few interesting products here on PM in the last year or so but haven't been motivated to change what works again yet.
