Rust removal from gage pins (yes, I know :))
Results 1 to 8 of 8
    Dec 2008
    IL/WI border
    3,428
    1234
    1066
    Default Rust removal from gage pins (yes, I know :))
    One of my .752"-.832" gage pin sets has some rust with minor pitting at one end of the pins. This set is not used for anything super precise, and the opposite 2/3 of the body end is in a perfect shape.
    I tried using phosphoric acid for the affected end, but it makes the surface dull grey. First of all, I wonder why. I know that Evaporust or phosphoric acid solutions remove oxides. But what's on the surface of a regular gage pin to become dull? Isn't it just a ground steel?
    Any other methods you'd prefer, or you just wouldn't worry about dull appearance? I assume that using phosphoric acid is less detrimental to the pins (vs. use of any abrasives, even the mildest ones like white scotch Brite, buffing, etc.)
    P.S. Yes, I certainly understand that rusted gage pins are thrown away and replaced. But this particular set is sufficient for my modest homeshop tasks.
    Mar 2009
    5,602
    103
    1084
    Always have to brush off the dull grey with a small brass or SS brush. Nothing else works better.
    For your gauge pin sounds like you don't want that method.
    Use a battery with electrodes in a soda bath. It will accentuate the pits but all the rust will be gone.
    Virginia
    31,944
    7561
    10039
    Quote Originally Posted by MichaelP View Post
    Tumble with walnut shell & rouge media, mayhap?
    Chemicals and 'lectricity would not be on my radar for "gage"-anything, even "hobby" use. I'd aside 'em for use as "project metal" first.
    Used-but-good, or new and cheap sets are plentiful enuf, if your one is too badly bonked.
    Jul 2008
    Philadelphia
    2,009
    538
    463
    You might go to you tube and look at Adam Booths vids, he uses a rust removal chemical, that works a treat on cutters. The name eludes me but contact him to find out what is.
    Feb 2010
    ch
    2,595
    220
    342
    the gray coating is phosphate. no good on a precision surface. rust converts before the coating appears with phosphoric. you have to find the right immersion time depending on concentration and temperature. take it out, brush and repeat maybe. if you try evaporust or molasses make sure the whole part is immersed, you get a parting line otherwise.
    Mar 2017
    245
    110
    Phosphoric acid will convert rust while evaporust is a chelating agent which removes it. Choose yer poison. The good news is that evaporust doesn't degrade the nonrusty parts, but be sure to completely submerge the pin.
    Dec 2008
    IL/WI border
    3,428
    1234
    1066
    Thank you everyone.
    After some experimenting, I went with Evapo-Rust and, per MrStretch's recommendation fully submerged the pins: partial submersion produced a grey ring at the liquid-air level. Held them in overnight with a pretty good result. There is some grey spotting here and there (not only on the rusted areas), but you cannot compare it with the effect of phosphoric acid where the whole surface became grey totally hiding the size marks.
    No apparent pin diameter changes after either of the methods though.
    After soaking in Evaporust, I wiped and oiled the pins. No attempt was made to wash Evaporust out prior to drying.
    May 2017
    Massachusetts
    387
    428
    200
    I’ve used evaporust with success as well (for shop grade). Unfortunately it removed the markings that indicate pin size. Kind of annoying but better than rust.
  9. Likes MichaelP liked this post
