xavier2089
- Nov 29, 2016
I have an old tool and cutter grinder that I am cleaning up.
Several collets and other bits and pieces have some mild rust on them. With reference to 'mild rust', say rust equivalent to the photo on the first page in the below link.
Obviously, the collets are hardened and tempered. Many processes therefore can cause hydrogen embrittlement.
I have read a few posts on derusting but am still undecided as to which are the best methods.
The best post I could see was: https://www.practicalmachinist.com/vb/general/rust-removal-335522/?highlight=cleaning+rusted+parts
Please let me know if this is covered somewhere else.
I am inclined to use one of the these options: Wire wheel (steel wire), Evaporust or Grandma's Molasses.
Any input on the following questions would be greatly appreciated.
Will the wire wheel cause the precision ground parts to become out of tolerance/ dimension?
If so, are there alternatives to a wire wheel such as a nylon wheel/ scotchbrite wheel, etc.?
I was planning on using steel wool to clean the inside of some of the parts (such as sleeves) whilst spinning them up on the work head.
Does Evaporust or Grandma's Molasses cause hydrogen embrittlement?
Is one more likely to maintain original tolerances using the chemical methods?
