I've been happy with a 36" Econoline cabinet
abrasive blasting equipment manufactured by Econoline).
Both top and side loading, with your choice of nozzle sizes (12 cfm, 25cfm), a foot pedal, air blast etc. This has much heavier (longer-lasting) steel, more even lighting, easier window shield replacements, a strong parts shelf, and better sealing than a friends import.
I've also heard good things about TP Tools, referenced above.
It's pretty easy to build a solid cabinet, but a bit harder to get the flow and ergonomics right the first time in a home built unit. As Ries suggests buy at least the critical components if you're building your own -- and then check other designs for ideas on windows, collection box angles, blast media change doors, and the like.
Make sure you have enough dry compressed air. A 5hp Quincy is just barely adequate for my 12cfm gun, despite having a higher cfm rating. I'll often parallel in another compressor.
McMaster Carr carries this line (though not identified as such), along with all replacement parts from gloves to nozzles. Good way to get an idea of pricing.
