The best advice is just to get some new fresh belts but......if you are sitting in quarantine with time on your hands and loathe to throw out unused but old belts, here is a plan. Clean the joint( old belts , you can easily pull apart the joint) with lacquer thinner and rough with sandpaper, coat the joint with Shoe Goo per instructions( contact cement for shoes, available everywhere) , make a jig so that the joint is straight. Now we are not done yet. Find some glass cloth reinforced tape, 3M Scotch #27 is what I had in the bin. Paint the Shoe Goo along the back of the belt far beyond the joint and install the tape on the tacky Shoe Goo, cut the tape so that the angle is the same as the joint. Put this in the jig with clamps and wait 24 hrs. Whew!, but this has held up for me..but allota work.
