I am looking for some help with the '1996" Haas VF3 that i use at work. I am having a spindle orient problem, it seems that the shot pin will not go into the hole to lock the spindle for a tool change.I've read that the solenoid may need cleaning. My problem is that I don't know where the shot pin and solenoid are located on the machine, can't see them after removing front cover from z axis. Can you help me locate, and tell me how to clean the solenoid? A service call is just to expensive at this time.
