Saw upgrade
Results 1 to 18 of 18
Thread: Saw upgrade
    Apr 2021
    Washington
    32
    26
    5
    Default Saw upgrade
    What determines how fast a band saw can cut?
    We have had a Cosen C-325NC saw that has been great for 10 years. It manages to keep up with our CNC lathes now, but we are about to double our production and this saw will not cut it.
    Are column style saws going to allow us to cut faster? Should we find something with more HP? Just buy a second saw? Run it overnight and clean up the mess in the AM?
    We cut 6061 round bars, 7-11" diameter, 10 hours a day, Lennox blade 1.25 X 0.042 - 2/3 TPI
    Sep 2014
    Georgia
    544
    382
    223
    Do your Lennox blades have carbide teeth? Are you running the saw close to 328 surface feet per minute, already?
    Have you tried an amp meter on the five-horsepower motor to see how much reserve you have?
  3. Likes digger doug liked this post
    Aug 2004
    Virginia
    2,849
    232
    1324
    In my opinion, it is always better to have another separate saw if you have the space and the money. obviously can double your output and when one craps out for some reason or other (blade breaks on Sunday and you don't have a blade welder or stock) you are still up and running.
  5. Likes GiroDyno, Scottl, 72bwhite liked this post
  6. #4
    Apr 2021
    Washington
    32
    26
    5
    Quote Originally Posted by David_M View Post
    312ft/min seems to be the sweet spot for this configuration. We picked this blade because it was suggested to us by our local saw supplier. Will look into higher feed blades for sure, just kind of curious if other styles of saw are inherently more productive.
    ***Just went and tested max speed for the saw is 340 so higher feed blades aren't necessarily a solution***
  7. #5
    Jun 2019
    794
    348
    872
    Quote Originally Posted by GiroDyno View Post
    Well you could look into cold saws. Most only handle smaller material though they do come in larger sizes.
    V-Series Billet Saw - Carbide Vertical Saw | Advanced Machine & Engineering Co.
  8. #6
    Oct 2005
    22,051
    Can you bundle cut ?
  9. Likes BT Fabrication liked this post
  10. #7
    Apr 2021
    Washington
    32
    26
    5
    I wish. Saw throat doesn't have the capacity and we also do a lot of variety so it would be hard to match lengths up anyways.
  11. #8
    Sep 2002
    People's Republic
    6,082
    723
    3755
    I love cold saws, but that would be a biiiiig cold saw.
    More horsepower, more aggressive blade.
    Wonder what your aluminum supplier uses for a saw
  12. Likes GiroDyno liked this post
  13. #9
    Dec 2012
    Se Ma USA
    2,240
    180
    1219
    I'm with the suggestions of adding a second saw. Having double CNC capacity means nothing without material for them to process.
    And not too hard to find a saw that can handle 2)7" bars at a time. Or even 4 at a time. Material handling needs to be a big part of the process too. The efficiency of loading and unloading is a big time factor.
  14. Likes GiroDyno liked this post
  15. #10
    Jun 2012
    Michigan
    5,987
    5642
    3813
    That saw can cut billet? It must be the best.
  16. #11
    Jun 2019
    794
    348
    872
    Well, he didn't specify that he wasn't willing to throw stupid amounts of money at his problem.
  17. #12
    Apr 2021
    Washington
    32
    26
    5
    Quote Originally Posted by CAMasochism View Post
    It's not my money
    Good point regarding material handling. We are currently trying to figure out a way to store and load material without the forklift.
    8.5, 9, and 10" diameters account for 90% of our parts so I guess I should specify those sizes are where our saw capacity should be focused.
  18. #13
    Sep 2012
    Minnesota
    284
    87
    99
    It's not my money
    I have seen jib cranes work well for loading saws without a forklift. One centered between the two saws could work nicely.
  19. #14
    Aug 2013
    Chicago, IL
    1,271
    915
    512
    Disclaimer - I deal exclusively in steel, not aluminum. I was taught that the speed is just a chart depending on the blade and material you are cutting. Then you increase feed pressure until you get "6" and "9" shaped chips. Dust is too light feed and big curly cues is too heavy feed. From there I think the blade pitch is just to make sure there is enough room in the gullets so they don't get clogged during the cut. There's some "rule of thumb" that says something like 12 teeth in the cut on solids, but I'm not exactly sure how that plays out with rounds.
    I believe the dual column just helps keep the cut straight, not necessarily faster. Keep an eye out for going-out-of-business auctions....all those shops have auto-feed saws. Also, I agree with getting a second saw as opposed to trading up.
    Good luck!
  20. Likes GiroDyno liked this post
  21. #15
    Sep 2012
    California, Ventura county
    2,062
    952
    908
    Sometimes the most obvious solution is the best one
    Get a second saw. Up side of that you can be cutting 2 different diameters at the same time
    If say at the end of the run of one part and starting up a different size one
  22. Likes GiroDyno liked this post
  23. #16
    Apr 2021
    Washington
    32
    26
    5
    Quote Originally Posted by 72bwhite View Post
    Running two different diameters at a time is a great point, with a high mix of parts that would be super helpful.
    But does anyone know if 2x the HP allows you to cut 2x as fast? Wondering if we get a second saw do we get the same size or would a bigger one be significantly faster, or does it just let you cut bigger/harder materials?
  24. #17
    Oct 2005
    Wilmington DE USA
    2,315
    380
    509
    Depending on the age of your existing saw and parts/model availability, consider getting a "twin" to your current saw.
    Operators will immediately know how to use it and may not fight over using the new "better" saw..
    Parts are the same.
    Particular problems of the model should already be known.
    The factor of doubling output is an easy calculation if material handing isn't am issue.
  25. #18
    Nov 2019
    CANADA
    Ontario
    643
    1015
    154
    2x the hp usually equals a bigger cut width on a band-saw. thus larger gang cutting.
    if its aluminum, a 20HP cold saw will be the fastest with automated bar feeder, could cut pieces in seconds. just need the $$$ to pay for it.
  26. Likes GiroDyno liked this post
