Scissor lift bearing identification
Likes Likes:  0
Results 1 to 9 of 9
    Feb 2002
    New Mexico
    6,082
    63
    649
    Default Scissor lift bearing identification
    I'm looking for the bearing in the images below - it's the pivot bearing on a scissor lift and I'm looking for the name of the bearing so I can find a source for several (I need at least 8 for a lift I'm planning on making).
    Dec 2012
    AUSTRALIA
    5,077
    35
    1837
    Probably a steel on steel spherical bushing.....Can be expensive in the bigger sizes Ive used for articulated loaders and cranes.
    Dec 2004
    Massachusetts
    336
    6
    37
    Maybe a cam follower bearing
    Jul 2006
    Hillsboro, New Hampshire
    14,319
    3132
    9522
    Maybe this link can help (from a search for "scissor lift pivot bearings"):
    Lift Bushings & Bearings - Hardware - Partsroom
    ["X" click through the "We're Closed" banner to see the page]
    Seems like a lot of metal and polymer bushings, not rolling element bearings. Obviously designing the pivots to prevent axial separation is critical...
    Also: https://www.igus.com/info/industries...ngmechanism-ca
    Sep 2004
    Wisconsin
    286
    79
    Looks about same material as excavator pins/bushings.
    Jul 2004
    Houston, TX USA
    32,456
    Appears to be weld bead both sides - which suggests welded in flanged pin one side and welded in bush other side - not coming apart until weld beads are gone
    Mar 2006
    jacksonville,fl.
    1,572
    1548
    537
    John has it right. Plane bearings are the way to go with no provision to separate. You definatly do not want a spherical bearing on any sissor linkage especially if you are riding on top of it. That set up is as simple, strong and fool proof as possible.
    Feb 2007
    St. George, Utah
    1,483
    996
    1039
    Probably nothing special. Most of the stronger alloys don't lend themselves to welding like that, and as long as you make it big enough for the load and keep it greased, even 1018 should be fine.
    Oct 2009
    Oregon
    6,596
    7034
    3913
    I don't think scissor lifts built in this century have used greasable bearings. They use IGUS or Garlock polymer metal composite bushings that don't need grease.
    My scissor lift is a 2008 JLG and there's no grease zerks on it. It works great.
