Seal for pneumatic air tamper
Likes Likes:  0
Results 1 to 2 of 2
    Mar 2005
    near Rockhampton, Queensland, Australia
    5,556
    443
    2084
    Default Seal for pneumatic air tamper
    I am currently working on using an air tamper to cut down on some manual labour but need some advice on seals. What I am doing is using a chinese made air tamper to ram up posts to save doing it by hand which is quite labour intensive.
    Being of cheap manufacture the current one uses leather packing as a seal to keep dirt out as it is used in the hole the reciprocating shaft gets dirt on it and so on.
    Wanting to install a cheap wiper seal to keep the innards free of dirt. It runs at around 5-10 beats a second with about a 2 to 3" stroke. It does not matter if the seal only lasts a few days provided it is cheap say a few dollars as it could be replaced in five minutes.
    Any ideas on a seal type in 14mm ID? I can get U cup seals for $3 each. It is the shaft speed that is the thing.
    Jan 2007
    Norfolk, UK
    19,309
    14774
    14927
    MMMM? this is me thinking aloud so please take it as such working on top speeds, 10 beats a second is 600 / minute, and with a stroke of 3'' that's 200ft / min which is not exactly fast, …..so I'd go for a say a neoprene etc etc type seal and assemble it with silicon grease.
