Secondary head mount on knee mill?
Results 1 to 8 of 8
    Jun 2021
    9
    Default Secondary head mount on knee mill?
    I have a new to me, old Lagun ft1 mill with the ring mount on the back of the ram for a secondary head.
    It has me curious what if anything they can be used for?
    It seems like a good place to mount some sort of extra head and just rotate around to use it.
    Duke
    Oct 2005
    22,051
    Quote Originally Posted by Jduke View Post
    Duke
    Sometimes similar mills mounted a shaper head there.
  3. Likes boslab liked this post
    Jun 2021
    9
    Seems like it might be a pretty good place to mount a home made Z axis if you were doing a cnc conversion.
    Duke
  5. Likes boslab liked this post
  6. #4
    Oct 2005
    22,051
    Duke
    You might want to move that discussion over to "the zone".
  7. #5
    Jan 2007
    wales.uk
    1,787
    384
    410
    Usually it’s a hanging point for a slotting head, I’ve one on the back of a Cincinnati, I’ve seen one with a high speed drill on the back too, that was cool too
    Mark
  8. #6
    Aug 2017
    Connecticut
    80
    18
    On Bridgeports there were several accessories that could be mounted with the right adapter to the end boss on the ram. These included but were not limited to Shaper attachment, slotting head, cherrying head, M-head, L-head, and I've seen on Series 2 4HP mills versions that also had a 1-1/2 or 2 HP variable speed head on the end boss so the ram could be flipped around and uses as a Series 2 Special.
  9. #7
    Oct 2009
    Olympia, Wa
    790
    342
    249
    Years ago I went to look at a milling machine and ended up buying it. It was backed into corner and when we moved it out there was a giant boring head sitting in that hole. I asked if that was included and they said sure. It was a 6" flynn.
  10. Likes sfriedberg liked this post
  11. #8
    Apr 2004
    Modesto, CA USA
    8,646
    1656
    You could mount a high speed wood router and use it for cutting dadoes. Use a plunge router and get more possibilities. I have seen pictures of a router mounted on radial arm saws. in place of the motor.
    Bill D
  12. Likes boslab, sfriedberg liked this post
