aribert
Cast Iron
- Jul 2, 2008
- Metro Detroit, MI
I'm a hobbyist so normally I post questions on a hobby maching forum but I figured the knoweledge base on this forum is much better for my question. My Summit 14 lathe has a 6 MT in the spindle. My question is how hard to tap the sleeve into the spindle?
Backstory - on my previous lathe, Clausing 5914 with a 4.5 MT, I made a 5C adapter and when I inserted the adapter to use it, I used the hand wheel to draw the adapter into the spindle. I made a 5C adapter for my current lathe, starting with a commercial 6 x 4 MT sleeve. I very gently tapped the sleeve into place, then machined/ground the sleeve into an adapter. Checking the run out its 10x+ more than I want it to be (now .005 in.). If I lightly tap the adapter with my lead hammer the run out is reduced to .002. I've adapted a Royal lever collet closer for this lathe instead of the handwheel on the previous lathe.
How hard should one tap on the adapter to seat it, since the load (impact from tapping) goes directly into the spindle bearings? I just don't have a feel for what is reasonable in this size of a taper. BTW, I inserted the adapter clocked the same way to the spindle as it was ground - not that that should matter.
