Seeking Advice on lead screw repair in Rochester NY
Results 1 to 13 of 13
    Dec 2020
    New York
    9
    Default Seeking Advice on lead screw repair in Rochester NY
    Hey all, I'm brand new to machining and recently acquired a mill with a broken lead screw. Luckily, it's not broken in the threaded area. I've been looking around for a machine shop to repair it, but I don't know much about the shops in my area and I don't want to take it somewhere that's going to charge me way too much or do a poor job. Basically, I need the end of it cut off, a hole bored in it, then a new piece stuck in the hole and welded, then turned back down to size, and a key way cut in the new end. If anyone in the Rochester, NY area could point me to a good shop, or if anyone can give me a range of prices to expect to have the job done, that would be super helpful. Hope everyone is having a good day, thanks in advance to anyone who responds to this!
    - Nick
    Dec 2020
    New York
    9
    Here's a couple pictures. It's right where the handle was on the left side of the table.
    20210403_111632.jpg - Google Drive
    20210403_111652.jpg - Google Drive
    Feb 2006
    Indiana
    13,885
    797
    4648
    I have done that repair about six times on Hardinge lathe feed screws. I silver braze the new part into the drilled hole in the old screw, which I think is a better choice than any sort of welding.
    Be aware that the screw ends get broken during an accidental bending/dropping event, so the remaining end of the screw that goes through the support bearing will probably be bent. On my screws, I was able to straighten that portion of the screw before drilling the hole.
    If done carefully, the repair will be as good as a new part.
    Larry
  4. Likes 1yesca liked this post
    Dec 2020
    New York
    9
    Quote Originally Posted by L Vanice View Post
    Larry
    It was dropped (about ripped my cousin's throat out for that one) and it is bent right up to the support bearing. Luckily, it's not bent inside the bearing and I have plenty of un-threaded length behind the bearing, so I'm just going to have them cut it in the straight section and do the repair a little further from the end of the screw. Any idea what that job costs, roughly, at a shop? I don't have a lathe so I can't really do it myself. Not properly anyway.
    Oct 2005
    21,678
    Is this a standard Bridgeport or similar copy ?
    Jul 2006
    rochester, ny
    2,329
    573
    737
    These guys do SERIOUS machine rebuilding in Rochester. Your job might be too small for them, but maybe they could recommend someone.
    Machine Tool Research, Inc. | Machine Tool Rebuilders
    Jul 2006
    Hillsboro, New Hampshire
    13,040
    2946
    8957
    Quote Originally Posted by richard newman View Post
    Mama-jama! Now I know who to take my 7 x 14 mini-lathe to for a tuneup...
  9. #8
    Jun 2013
    New York
    903
    612
    481
    Quote Originally Posted by apache1649 View Post
    - Nick
    I'm in Niagara Falls. If you can send both pcs to me, I can fix it for you. It's very similar to the stuff I do on my day job. Figure sending it in the mail is gonna be cheaper than the gas to drive to and from Rochester. I'm a pro welder/fabricator who happens to own a lathe.... could possible save the original end it looks like. All that it'll cost you is the shipping both ways, and waiting a bit.
  10. #9
    Dec 2020
    New York
    9
    1928 Brown and Sharpe No. 2 Horizontal
    Thanks for the tip
    Quote Originally Posted by pavt View Post
    I'll DM you shortly
  11. #10
    Dec 2020
    New York
    64
    29
    6
    Send it with some tracking or use a courier. Mail around Western New York is having a little trouble right now.
  12. Likes pavt liked this post
  13. #11
    Jan 2005
    CANADA
    Saskatchewan
    10,339
    1417
    3774
    The way to fix that is to weld on a new (oversize diameter) piece onto your screw, and remachine all the features on that end.
    Salvaging the bent end is a total waste of time. Trying to weld a piece on straight is also a waste of time.
    I'd charge between one and two hundred dollars.
  14. #12
    Jun 2013
    New York
    903
    612
    481
    Quote Originally Posted by Euclidean View Post
    Yep, that's a good idea to use tracking in a mailing tube or something. Mail is indeed a bit flaky lately. I ordered something from Chicago a while back, it got as far as the Buffalo PO and they bumped it to.... Oklahoma! Three weeks later, my wrench arrived....
  15. #13
    Sep 2010
    Oklahoma City, OK
    5,494
    1060
    2396
    I didn't think youd mind me borrowing it...
    Sent via CNC 88HS
