pianoman8t8
Hot Rolled
- Nov 14, 2012
- Maine, USA
Hi all,
I think I have at least 1 involute spline I need to reproduce. It's a driveshaft for an old tractor that's no longer available, shaft snapped, 21tooth spline at one end, 19tooth spline at the other end. Maybe weld, re-turn section, re-harden? Doubt it would be overly straight after that...
Edit: This post was more intended to see if the cutter selection was similar to spur gears? Or, since it's a spline, different? I've cut a couple spur gears way back in trade school, but no gears since then, and no splines.
1st spline is approx 0.908" OD, 0.775" minor, 21 teeth.
2nd spline is approx 0.780" OD, 0.690" minor, 19 teeth. Considerably "flatter" teeth. Worn?
