Shawn_Laughlin
- Mar 28, 2019
What cat40 tooling do you use brand wise and what would would you get today if just starting off with a new,let’s say HAAS VF3ssyt and it was your first machine?
I’m new to cnc but not to machining so I know nothing of 12 to 15k spindles speeds. I know that the holders need to be balance rated for the at least the rpm But I will probably go with a higher rated holder. Is that overkill or smart? Also I would imagine face mills/shell mills have a balance rating as well,I actually have never researched that one but will.
So like I said above,if you were starting out today with your first cat40 12 to 15k spindle what brand and size tooling would you buy to get started? And if you know of any decent packages let me know where to find them? Thanks
