Has anyone any references to aid in the construction of a sensitive grinding spindle suitable for bench lathe applications?
I would like to produce something with about 2 inch stroke.
A device that would fit up to the KDK QC tool post, even if just clamped in the usual tool position, and be powered by.....? an overhead/back bench jocky belt system.
I am considering plain bearing construction for compactness and quietness. Preferably a C.I yoke and a length of 7/16 or 1/2 inch drill rod for the quill. The work end to be threaded 3/8- fine to suit jacobs rubber flex collet chucks. The "handle may indeed be fitted with a ball bearing as a suitable finger hold ;-) The drive could be centered between bearings or less desirable I think, on the handled extremity.
Comments on the use of oilite or other self lubricating bearings? I am not opposed to having spares on hand and renewing them frequently. Or would C.I. rod turned up as "replaceable bearings" be a better choice? I could not help but put a drop of "turbine oil" at the correct location before any use ;-)
A lapped close running fit is what is desired. I could appreciate a clamp up housing to extend the service life of any bearings.
This link shows commercial offerings, but without the feature of "stroke", I may as well stick with the tool post grinder.
www.anglo-swiss-tools.co.uk/grindingspindles.html
Thus far, I have not run across any vintage equipment nor have I seen raw castings suited to this task.
A Levin unit is "too much". in many ways.
All comments welcome!
CalG
CalG
