Have any of you guys changed the little black bulb/seal boot on the rapid push switch of Servo type 140 drives? what's the trick?
I got one that is finally ready to be replaced, I assumed it would thread off since its got a hex nut shape at the bottom but I gave it a few turns and its clearly not unscrewing, its just spinning(worried about it ripping a wire off inside now). Do they just pry off or do I have to open the whole thing and hold the switch from the inside? I can't imagine it would take all that much work just to change that little thing.
thanks
thanks
