Servo Products Type 90 Specificatios
Likes Likes:  0
Results 1 to 4 of 4
    Jan 2008
    W. Palm Beach
    Default Servo Products Type 90 Specificatios
    I've got an old Wells Index 747 with type 90 power feeds. When I got the mill the power feeds didn't work. After replacing some micro switches everything was fine. The other night I noticed the "y" axis feed started tripping the breaker which eventually ended up destroying the breaker. I pulled it apart and replaced the SGRs and now I don't have the tripping condition but I have no movement at all.I've measured voltage at the brush holders and it's reading around 60v regardless of the position of the speed knob. So I have three questions: 1) Does anyone have a schematic for the IC Board? 2) Am I correct in thinking that the drive motor is an A/C reversible induction motor with full wave rectification and 3)What peak voltage should I be detecting at the brush holders. Thanks!
    Feb 2006
    Indiana
    13,780
    787
    4556
    I think that "A/C reversible induction motor with full wave rectification" might more likely be a shunt wound DC motor. In that case, the brushes will have a constant voltage and the field voltage will be varied to vary the speed. Or it could be a series wound DC motor with an SCR control.
    Larry
    Jan 2008
    W. Palm Beach
    Larry, Thanks for taking the time to post your suggestions. It would make sense that it might be a DC motor as there are a bunch of heavy diodes and two SCRs on the IC board. I was thinking it might be an AC motor do to the way the armature looks. More reading needed on my part.
    Nov 2008
    AK
    47
    54
    14
    Wayne, at Bridgeport Knee Mill Parts in stock-Bridgeport and Servo power feed parts and service is a hell of a resource for the old Servo drives. He still the parts I needed to get my 70 series Lagun back in service. Mine ended up being a bad speed control pot. Does yours work if you press the rapid traverse? That pretty much bypasses all the variable speed components.
