I'm attempting to align the shafts parallel to one another on this piece of machinery I'm putting together, and I'd like to be able to do so without purchasing expensive laser aligning tools, etc.
My first thoughts are to pick a reference shaft, hang plumb bobs for vertical reference lines at each end of the shaft, and measure from the shaft being aligned to those reference lines. I'm using a starrett protractor head with the rule set 90 degrees to the head in order to give two faces to butt up against the shaft, and then I use the built in level on the protractor head to level the rule up while taking a measurement at the reference lines.
Doing it this way is bit tedious and not very precise. I'm thinking there is a better way to do this. Any thoughts?
