Sharpening coffee grinder burrs! - Page 2
Results 21 to 40 of 46
  1. #21
    Oct 2005
    11,040
    17978
    5825
    So where did all the metal go that wore off .....
  2. Likes SWYooper, MichaelP liked this post
  3. #22
    Mar 2018
    CANADA
    Quebec
    13
    5
    Quote Originally Posted by HuFlungDung View Post
    I'd assume these are center feed, and that the bigger gashes are spaces for the whole bean to get in between a pair of plates. Are they precisely shimmed so that the blades don't contact, or do you have a specified clearance for a particular grind coarseness?
    I can see after extensive or repeated resharpening, that you'd loose some capacity if the larger beans cannot fit into the big gashes, so you might have to regrind that part a little deeper if much material is removed.
    However, I still think a flaring cup CBN wheel could be configured to work on a VMC, but that's not a DIY project either. Sounds like you're only paying about $10 per blade, ($350/12)? That is so cheap you'd have to automate it. T&C grinding with a soft pink toolroom wheel would have you pulling your hair out, IMO. Nice to grind with, but the stone wears quickly. Round and round and round, you'd go, trying to keep the wheel flat so it doesn't turn over the edge. Or am I wrong? A super-abrasive like CBN would probably not wear significantly. I don't see any need for a razor sharp corner in the bottom of the flutes, so maintaining an acute corner on the wheel wouldn't be a big priority, perhaps.
    its 350$ per set of blades and i have 12 sets! so 12x350$! thats when they offered the regrinding. now they dont offer it anymore and sell those sets of blades for 750$ per so 12x750$ it goes pretty far since i have to regrind em each year pretty much! You got it right they are center feed! As far as clearance i can still adjust the numbers on the adjusting wheel so i get the grind i want!
    Thanks alot !!
  4. #23
    Mar 2018
    CANADA
    Quebec
    13
    5
    You would be surprised to see what we find in green coffee bags, pieces of concrete and 3 inch nails are pretty common lol!
  5. #24
    Jul 2006
    Hillsboro, New Hampshire
    5,139
    1202
    3589
    As long as you can keep the blade edges from touching, this may be a good application for DLC (diamond like coating). Even with the natural mineral uptake of the growing beans, there should be a significant lifespan added when coated, and it should reduce excess heat by staying sharp and having lower inherent friction.
    If the blades do contact one another (and it looks like they do), then it's possibly not worth it. Is blade contact a given, or is it due to improper adjustment?
    I don't even drink coffee, but this is of academic interest...
  6. Likes Mooner liked this post
  7. #25
    Mar 2018
    CANADA
    Quebec
    13
    5
    They usually are not supposed to contact! But you know sometimes it happens if we are not careful when we install them! Id say they maybe contacted 1% of their whole life. They list their new blades to 15k pounds of coffee untill you have to change them!
    Thanks for the idea i will look into that
    Alex
  8. #26
    Jan 2007
    Norfolk, UK
    17,240
    12908
    12498
    Thanks for an interesting topic, .....and from what little I know of cutter grinding - that is definitely a job for a proper grinding shop that really knows what it's doing.
  9. Likes AlexyL liked this post
  10. #27
    Aug 2015
    Illinois
    934
    740
    383
    I am thinking that a tool & cutter grinder with a universal grinding fixture like the Uni Head could be adapted to do the job. It would just need a locating flange that can be rotated. I suspect the teeth could be indexed with a spring finger. I would be tempted to try it just to see if I could do it. It would help to look at a new burr to see what the angles and tooth heights are supposed to be.
  11. Likes TDegenhart liked this post
  12. #28
    Jan 2005
    CANADA
    Saskatchewan
    9,719
    1209
    3359
    We eat and drink it All sorts of food processing equipment wears out imperceptibly over many hours/days, even when operating properly: hammer mills, screw expellers (oilseed pressing)....it's in the product.
  13. #29
    Jul 2006
    5,139
    1202
    3589
    Well, this puts the BBQ grill I made from leftover plutonium into a whole new light!
    Speaking of, am I the only person that doesn't need to turn on a night light when a nocturnal bathroom visit is needed?
  14. Likes AlexyL liked this post
  15. #30
    Alpine california usa
    97
    113
    20
    Most of the damage to the burrs comes from the material found in coffee rocks nails wood. As coffee is dried on cement patios and raked then when it’s dry to proper moisture it’s shipped. Roaster can use a destoner to separate the coffee bean from any debris they also use rare earth magnets to collect stones.
    B
  16. Likes digger doug liked this post
  17. #31
    Jan 2005
    CANADA
    Saskatchewan
    9,719
    1209
    3359
    Quote Originally Posted by AlexyL View Post
    Thanks alot !!
    Yes, that is some serious money. I find it crazy that they can make new ones, but cannot sharpen old ones. Something rotten there.
  18. #32
    Jan 2005
    CANADA
    Saskatchewan
    9,719
    1209
    3359
    Quote Originally Posted by Drroaster View Post
    B
    I recall from my youth while on the farm, that we used to grind 'chop' for animal feed with a 'double disk grinder' I think my Dad called it. He used to really jump for the quick release when a nail got in there. He had to be mighty quick though, a nail didn't last long in there
    Grinding chop was a big deal, getting ahold of some borrowed farm tractor that still had a belt pulley on it, getting it all hooked up and blocked for stability. We ground a small granary full at a time, enough for a year, as I recall.
  19. #33
    Jul 2005
    Eastern PA
    883
    112
    574
    If you need a light to find your wang there's more problems than metal in your coffee........Bob
  20. Likes MichaelP liked this post
  21. #34
    Oct 2005
    11,040
    17978
    5825
    George Carlin had a good piece about the government regulations
    concerning maximum allowable "Bug parts" and "Rodent Droppings"
    in hot dogs......
  22. #35
    Mar 2011
    Geneva Illinois USA
    5,063
    1988
    1892
    B
    Magnetite maybe but granite and limestone?
    Tom
  23. #36
    Jun 2005
    Edmonton,Alberta,
    1,180
    145
    90
    There is a landing area on the circumference for times when the machine is turning without coffee beans. Usually the beans keep the burrs separated even when they are really close together such as when set for a turkish grind.
  24. #37
    Aug 2014
    bainbridge island
    868
    150
    214
    Quote Originally Posted by TDegenhart View Post
    Tom
    Depends on the granite. my black granite surface plate can hold up a neodymium magnet, i've tried a few other granites and can't feel any magnetic attraction.
  25. #38
    Mar 2018
    CANADA
    Quebec
    13
    5
    Wink
    Ive called a couple tool/knife sharpening shop and found one that has done some before so im going to let him do his job on one set and see if its going to work! Ill post a picture here!
    Thanks alot guys!
    Alex
  26. #39
    Sep 2006
    SE PA, Philly
    5,178
    947
    1650
    Alexy, you have 12 sets of these things, and each set is supposed to handle 15,000lb between sharpening. And you resharpen every year. That's 180,000lb/year of coffee. 700 lbs a day. Wow!
  27. #40
    Dec 2004
    uk
    12,808
    3696
    5797
    ^ And i thought i had a problem now a days needing 2 cups to get the day rolling.
