Hello everyone!
I have a mechanical shearing machine of 2500 mm width capable of cutting upto 12 mm mild steel.
Lately, weve been trying to shear 6mm high tensile steel with max UTS at 900Mpa, and it is causing big chips on our blade (refer the photo attached).
The current shear blade is of D2 Steel, someone recommended that I should change the blades out to shock resistant steel. What are your opinions on this?
Photo:: Dropbox - WhatsApp Image 2020-09-10 at 4.52.21 PM (1).jpeg - Simplify your life
