sheldon lathe
Results 1 to 8 of 8
Thread: sheldon lathe
    Nov 2019
    Arizona
    Default sheldon lathe
    newly working for a machine shop, they have this old Sheldon Lathe they use from time to time. the cross slide feed auto slips sometimes. looking for a part list for the collar and collet to replace. they won't let me take apart to get sizes.
    Mar 2009
    Brunswick Oh USA
    4,520
    5025
    2691
    What sizemodelnumberyearcolorandotherspecsdoyouhavesowe canhelp?
  3. Likes Ron Hofer liked this post
    Mar 2011
    Geneva Illinois USA
    6,159
    2613
    2387
    Quote Originally Posted by Ray Behner View Post
    Love your punctuation.....not!
    Tom
    Feb 2007
    St. George, Utah
    870
    398
    551
    Quote Originally Posted by almoose View Post
    As mentioned above, the lathe model would be helpful. I you don't have that, a picture. Is it geared-head or belt drive?
    Usually, if the feed slips on a Sheldon it is because of a missing or sheared key.
    Jan 2005
    Victoria, Texas, USA
    4,004
    2150
    1007
    If it is a later built Sheldon lathe, the clutch pack in the apron needs adjusting. It's a simple adjustment of loosening a set screw on the collar on the end of the clutch shaft where the hand lever attaches. Rotate the collar about 1/2 of a turn, lift up on the lever and determine if it is making better engagement. If so, tighten the set screw and you're ready to go. If not give it another 1/2 turn, and if that does not work, time to take the apron off and do a clutch rebuild and what ever else needs fixing in the apron.
    If it is an older Sheldon with the old cone clutch arrangement in the apron, it will require rebuilding the apron.
    Ken
    Feb 2007
    St. George, Utah
    870
    398
    551
    Ken, that was my first thought too, but the OP only mentions cross-slide feed. If the long-feed doesn't slip it may not be the clutch.
  8. Likes 4GSR liked this post
  9. #7
    Mar 2009
    Brunswick Oh USA
    4,520
    5025
    2691
    Gordon
    The R model has separate clutches
    Tom
    For every word I type I discovered if I add another letter then backspace then use the space bar I create a space. Comp is screwed up
  10. #8
    Dec 2015
    Illinois
    412
    138
    230
    Ilikedtheotherwaybetter,lesswastedspace.
