trident marine
- Oct 20, 2009
- st-augustine-fl-usa
Hello,
My lathe model is Sheldon R15 I believe it was made in mid-1966, the s# is 32297 the change gearbox is a concealed unit with two dials located on the front of the lathe to rotate to the desired speed and feed. However under a cover on the left side of the lathe, there are three pullies coupled withe a timing belt style (an idler/tensioner pully a drive pulley, and a headstock drive pully, please note that they are pullies, not gears, with straight rectangular teeth.
Thank you for your reply.
-Adam
-Adam
