Hello PM~
This is a mini mill for hobby use.
But I have been using them for production for small plastic parts.
at first it was ok, but some complicated movements are required soon after.
But the original screw is terrible for CNC.
it is only 1mm pitch with 8mm diameter lol
the but is like 11mm OD.
you can imagine a design like that will develop backlash quickly and not last...
So, I thought of retrofitting the X and Y axis with ballscrews.
the biggest problem is everything is designed so small!
so the screw has to be offset to the side (the ball nut is too big to be placed centrally)
I have some used KURODA 8mm ball screws lying around, so that should do the job for small scale plastic part production.
surprisingly the teflon plastic gibbed anodized aluminum dovetail ways are quite reliable for plastic parts.
I haved owned this machine for 7~8 years and shows no sign of wear!
I have machined numerous parts on this machine, and also some aluminum as well.
there's virtually no wear and tear (aside from my mistakes)
so there is no need to install linear guideways.
hopefully I can complete this project without major problem!
